Resistor Box and Injector question
Old Dec 1, 2002 | 10:31 AM
Hondasaurs's Avatar
Default Resistor Box and Injector question
I have an Injector resistor box out of a 89 CRX si. I have the four fuel injectors. They are cut away from the resistor box. On the box there are 4 red/black and 1 yellow/black. My question is: Does it matter what injector goes to what wire coming off of the resistor box? If it does matter can some one please tell me the proper way to hook up the fuel injectors to the box.
Another question I have is will the 89 Integra PG7 ECU work or do I need the Si ecu?
[Modified by ZC_CRX, 2:41 PM 12/1/2002]
Old Dec 1, 2002 | 11:59 AM
Kataku2K3's Avatar
Default Re: Resistor Box and Injector question (ZC_CRX)
It doesn't matter which red/black wire you use for each injector.... Just make sure on the interior harness that you connect the 2 main injector grounds then run them to the box from there..... Also the PG7 should work just fine....
Old Dec 1, 2002 | 12:26 PM
Hondasaurs's Avatar
Default Re: Resistor Box and Injector question (JDMspecEG6)
What are these two grounds and where are they located?
markgo
Nov 8, 2006 11:39 AM
d16racer
Apr 2, 2006 11:40 PM
Boosted_93_Si
Oct 9, 2005 05:48 PM
JBk24crx
Oct 24, 2003 12:43 AM
-Bionic-
Sep 30, 2003 02:06 PM
