Axxis Ultimates question...
I recently installed ITR calipers on my GS-R and i finally got a chance to drive it. I am using Axxis Ultimates, but i have no shims on them. Do i need them? I did not put an grease on them either...
Ok, but when i was driving it, the brakes were smoking. I felt the rubber on the outside of the pad, and it was soft. I did not put any of the grease on, but the pads/rotors are new so maybe thats the cause?
remember to take some time to "break-in" you new rotor and the brake pad before you give full force.
You are susposed to wipe off the rotor with paint thinner before you install them to get all of that grease off of them, and then you won't have any problems.
And make sure you bed the pads in correctly.
exactly. You shouldn't have a problem without the shims.
tj
Marcos
Jul 21, 2004 11:45 PM
