well i need any larger injector for turbo R
here is my setup just for now
drag turbo kit
act clutch
VAFC
and some gauges.
my car is stock now, and i'm planing just to run 4.5 psi, will i need any larger injector ?
drag turbo kit
act clutch
VAFC
and some gauges.
I would go with 370cc or 440cc. Low fuel pressure is your friend and you can bring the fuel delivery down with the VAFC. You will need a fmu with 4:1 - 8:1 plate or something. On stock compression you can boost 7psi safe.
IMO no Honda with f/i should run on those tiny 240cc. They are maxed out already on stock engines.
Why bother running a turbo if your only going to built 4.5lbs of boost? Just curious?
Mattj
Mattj
but now ... safety first.
plus with 4.5 psi i getta learn how to handle the car on track.
[Modified by GettaluvR, 1:46 PM 11/30/2002]
You will need a fmu with 4:1 - 8:1 plate or something. On stock compression you can boost 7psi safe..
drag turbo kit
act clutch
VAFC
and some gauges.
drag turbo kit
act clutch
VAFC
and some gauges.
i'm going to run 370cc since i already have them, you could run 370cc up to high 200's, like 280-290whp, but your fuel pressure would be high too, i plan to with .3bar spring (4.3psi) + hondata + 370cc injectors and don't plan to make more than 220-240whp.
i'd suggest to wait for hondata, if you plan to run it anyway.
4dr*sleeper
Aug 16, 2005 12:33 AM
