Magnetic Tranny Drain Plug?
I got a 99cent drain plug from autozone for my oil pan and it got alot of metal shavings out of my oil I was happy...
I know spoon and mugen make then for the tranny too but for 40bux..thats alot...Does autozone make one?
They're the same thread size, different length.
The oil drain plug is shorter than the tranny plug, but you *should* get the oil plug to fit in the tranny.
I wouldn't do this, if you loose lubricant, you break things. Your call.
There should already be a magnet in the Transmission oil reservior. Most cars have them to catch metal shavings. You wouldnt be able to clean it out unless you dropped the cover.
Yes, there are magnetic drain plugs with the 14 x 1.5 thread size. The bolt head is 14mm instead of 17mm but makes no difference. It costs about $4 each and fit both the transaxle and engine oil pan. Pay 10X and be bling bling Spoon if you like.
There is already a magnet in the transmission anyway. See (5)
[Modified by markpaco, 7:20 PM 12/7/2002]
exactly, people dont see their toda cams either, nor do they see their higher compression pistons, or forged rods, or any of thier internals, hense the name "internal", hahaah
anyays, i'm going to napa 2morrow and see if i can find this shiet, thanx all!
vannak_5415
Oct 6, 2008 05:34 PM
underrated99si
Jan 19, 2003 01:36 AM
