Please Help..20 degrees outside and I have no heat!
Old Nov 29, 2002 | 11:45 AM
ylwbastrd's Avatar
Default Please Help..20 degrees outside and I have no heat!
I just picked up a 95 Integra LS recently from this guy. The A/C works fine..but when you turn it to Heat..no hot air comes out..just cold...I checked all the fuses and even the fuse in the engine bay labeled "heater motor" and everything else looked good...someone told me to check my coolant..could this be it..? also what else should i look for?
Thanks in advance..
Old Nov 29, 2002 | 11:57 AM
10K2HVN's Avatar
Default Re: Please Help..20 degrees outside and I have no heat! (ylwbastrd)
drive it in 3rd gear to keep the engine hot! lol
Old Nov 29, 2002 | 12:02 PM
PM-Performance's Avatar
Default Re: Please Help..20 degrees outside and I have no heat! (10K2HVN)
yea check the coolant . when i had my bimmer the dealer cut my coolant line therefore it all leaked out and ai dndnt knwo it , and I had no heat, but the car over heated too .
is it over heating ?
if not check the thermostat i guess to see if that needs replacing . thats the next logical thing i would guess.
[Modified by itr206, 1:02 PM 11/29/2002]
Old Nov 29, 2002 | 12:06 PM
ylwbastrd's Avatar
Default Re: Please Help..20 degrees outside and I have no heat! (itr206)
WooooooooooooooHooooooo...i just fixed it..i'm the dumbass that didn't use SEARCH for the first time....i was reading another post that said to check underneath the passenger side of the dashboard inside the car and you should see the lever move back and forth when you turn from COLD to HOT air...mine was completely disconnected...reconnected and everything is Fannnnnnnnnnnnnnnnnn-tas-tic..
thanks
theorigkav3
Feb 9, 2011 11:49 AM
TXGrunt
Feb 18, 2007 02:53 PM
95GS-R
Jul 5, 2005 08:06 PM
BigChris
Apr 26, 2003 01:50 PM
