b16a idles from 1000 to 2500 continously
Old Nov 29, 2002 | 08:59 AM
kamciu80@aol.com's Avatar
Default b16a idles from 1000 to 2500 continously
need help my car idles from 100o rpm to 2500 continuously. some told me that it was the icm valve? if anyone knows what the problem is or can help please do so.
Old Nov 29, 2002 | 09:25 AM
pkek's Avatar
Default Re: b16a idles from 1000 to 2500 continously (kamciu80@aol.com)
yeah you have a vacuum leak...
here's what i did
it's the IAC valve right below my TB on my intake manifold. its real ghetto but a better solution is probably around the corner...
I cut out a piece ov vinyl rubber material i had laying around from some bag or something, you just need somethign that wont leak
then remove your IAC and put this piece across the three holes, then bolt back up.
shoudl do the trick, mine used to crazy idle as well..
Old Nov 29, 2002 | 04:53 PM
DSeriesBeeKilla's Avatar
Default Re: b16a idles from 1000 to 2500 continously (pkek)
Old Nov 29, 2002 | 07:22 PM
kingpen's Avatar
Default Re: b16a idles from 1000 to 2500 continously (99D16VTECCivic)
Old Nov 29, 2002 | 08:33 PM
FDragger's Avatar
Default Re: b16a idles from 1000 to 2500 continously (kingpen)
check all your vacuum lines running to the intake manifold. you probably just missed one.
Old Dec 6, 2002 | 07:24 AM
pkek's Avatar
Default Re: b16a idles from 1000 to 2500 continously (FDragger)
i don teven have a breathe rline going from my valve cover to my intake tube, a few honkeys at a gas station said that was the problem but then i fixed it my way, and its still fine with ojut one
Angel23
Sep 10, 2012 01:52 PM
RiversideS13
Jul 18, 2007 11:08 AM
importimage
Jun 14, 2003 10:46 AM
