How to ID 2001 ITR cams????
Old Nov 29, 2002 | 08:22 AM
NeedMOPower's Avatar
Default How to ID 2001 ITR cams????
I am buying 2001 ITR cams of a guy and i want to know how to ID then to make sure they are authentic..
how would i go about doing this???
Old Nov 29, 2002 | 09:31 AM
skafia's Avatar
25 Year Member
Default Re: How to ID 2001 ITR cams???? (SleepyCivic)
Check the part #:
[Modified by skafia, 10:34 AM 11/29/2002]
Old Nov 29, 2002 | 10:37 AM
Default Re: How to ID 2001 ITR cams???? (skafia)
thanks that helps alot
Old Nov 29, 2002 | 11:04 AM
skafia's Avatar
25 Year Member
I don't think I agree with the picture cause it lists the 95-00 JDM cam as the same cam as the USDM cam.
You would think that CTR/US 00+/ and JDM 00+ use the same intake cams?
BTW, I want to hit a 13.9 also.
[Modified by skafia, 12:05 PM 11/29/2002]
Old Nov 29, 2002 | 02:18 PM
hummm...well i am going to look into the 3 rings on the end of the cam...i think that might be correct.
What do you mean by that???
Old Jan 18, 2003 | 07:18 AM
youngvedder's Avatar
Are these accurate Part numbers:
#14111-p73-j01
#14121-p73-j00
Just want to confirm.
cheers,
YV
Old Jan 29, 2003 | 12:14 PM
RedGSR's Avatar
Default Re: How to ID 2001 ITR cams???? (youngvedder)
is the part number on the cam? How can I tell ITR cam from GSR cam?
Old Jan 30, 2003 | 06:32 AM
vizeta's Avatar
Wait a minutes, so the easiest way to ID the ITR cam is look into the 3 rings on the end?
Old Jan 30, 2003 | 08:51 AM
EK Ferio's Avatar
Civic Type R cam part no. is 14111-PCT-000.
Old Jul 20, 2003 | 02:07 PM
badkarma's Avatar
So the 97 ITR cams don't have the double notches? Are there part #'s on the cams themselves?
Old Jul 20, 2003 | 02:11 PM
uNF$@#!'s Avatar
Default Re: How to ID 2001 ITR cams???? (badkarma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by badkarma &raquo;</TD></TR><TR><TD CLASS="quote"> Are there part #'s on the cams themselves?</TD></TR></TABLE>
no.
gsrsuperman
Jul 3, 2010 12:44 PM
overrr
May 4, 2005 07:12 PM
RedGSR
Jan 29, 2003 06:47 PM
NeedMOPower
Nov 29, 2002 04:47 PM
ghettoracer
Dec 4, 2001 03:53 PM
