when does vtec DIS-ENGAGE???
Old Nov 28, 2002 | 08:09 PM
typeee's Avatar
Default when does vtec DIS-ENGAGE???
is it the same as engaging, 5700rpm, or different?
Old Nov 28, 2002 | 08:11 PM
sackdz's Avatar
Default Re: when does vtec DIS-ENGAGE??? (itr707)
5400?
Old Nov 28, 2002 | 08:12 PM
nEoMuGen's Avatar
Default Re: when does vtec DIS-ENGAGE??? (sackdz)
5400?
Old Nov 28, 2002 | 08:14 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: when does vtec DIS-ENGAGE??? (nEoMuGen)
Anyone know why honda decided to turn it off at a lower RPM?
Old Nov 28, 2002 | 08:15 PM
B2FiNiTY's Avatar
I thought it was 5500...Does your vafc say 5400 neomugen?
Old Nov 28, 2002 | 08:26 PM
acuracing's Avatar
Default Re: when does vtec DIS-ENGAGE??? (Rguy)
To keep emissions down is my guess.
Old Nov 28, 2002 | 08:44 PM
thk's Avatar
thk
Members Only
Default Re: when does vtec DIS-ENGAGE??? (acuracing)
If it switches down to the primary lobes later, it's not for emissions. You want to switch back down to the primaries earlier for emissions. It's probably to keep the car within it's powerband between shifts.
Old Nov 28, 2002 | 08:52 PM
sackdz's Avatar
Default Re: when does vtec DIS-ENGAGE??? (thk)
The GSR could benefit from a little lower disengagement for sure.
Old Nov 28, 2002 | 09:19 PM
TypeR 599's Avatar
who fucked up the title?? =/
Rguy's Avatar
25 Year Member
Community Builder
Default Re: when does vtec DIS-ENGAGE??? (TypeR 599)
I saw that too..
Old Nov 28, 2002 | 09:20 PM
Reid's Avatar
Global Moderator
I don't know who changed the title in the first place, but I changed it back since it was making my head hurt.
Old Nov 28, 2002 | 09:22 PM
Mike M's Avatar
Founding Member
Default Re: when does vtec DIS-ENGAGE??? (Reid)
Yeah what the hell who did that.
Old Nov 28, 2002 | 09:30 PM
StinkyTofu's Avatar
Default Re: when does vtec DIS-ENGAGE??? (Mike M)
Well you can't have it disengage at the same rpm because what is the car gonna do when it hits X Rpm? Disengage and engage at the same time? If you disengage it higher than the engagement point, you have more of a chance to fall out of the power band. Either way, i don't think +/- 100 rpm is going to make a difference that is noticeable.
Old Nov 28, 2002 | 09:32 PM
nEoMuGen's Avatar
Default Re: when does vtec DIS-ENGAGE??? (B2FiNiTY)
That's how my VAFC reads at stock settings.
I only know a rule of not setting the disengage more than 400 rpm than engagment. The car will act real tard.
[Modified by nEoMuGen, 1:32 AM 11/29/2002]
Old Nov 28, 2002 | 10:03 PM
mugenracer's Avatar
the vtec light on my vtec controller shows mine doesnt dis-engage to near on 4000-4100rpm
Old Nov 28, 2002 | 10:07 PM
uNF$@#!'s Avatar
5400?
its 5600 stock ecu setting.
Old Nov 28, 2002 | 10:58 PM
nEoMuGen's Avatar
Default Re: when does vtec DIS-ENGAGE??? (Soup ****)
So VTEC engage at 5700 and disengage at 5600? That doesn't sound right. The rule of thumb is 300 rpm in-between the the low-hi, high-low.
Old Nov 28, 2002 | 11:12 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
i would figure that the point of it being lower is that once you hit it, if you are just erratically blipping the throttle around that point, it doesn't constantly go in and out of VTEC
Old Nov 28, 2002 | 11:14 PM
SoCal ITR's Avatar
Default Re: when does vtec DIS-ENGAGE??? (dLo GSR)
I think this is right. I'm pretty sure it's 5400, if I remember correctly.
Old Nov 29, 2002 | 01:38 AM
uNF$@#!'s Avatar
.... not quite.
5600 - off
5900 - on.
Old Nov 29, 2002 | 05:35 AM
Dirt's Avatar
FWIW, when I installed my VAFC on my GS-R last year (when I had it), the factory settings were 4400 engagement, 4300 disengage. When I upped the crossover to 4900, I set the disengagement to 4800. So I am assuming the R disengages at 5600 (100 rpm under the engagement).
gray_civic_coupe
13
Oct 14, 2005 01:28 PM
DXDOHCVTEC
Aug 27, 2003 09:09 PM
willywonka
Aug 11, 2003 01:15 PM
Magick211
21
May 21, 2002 11:17 PM
speedymon
Dec 24, 2001 02:15 PM
