Cruise Control Removal "?"
Old Nov 28, 2002 | 12:25 PM
Beave0101's Avatar
Default Cruise Control Removal "?"
Yea i've searched this forum, and clubsi, and PM'd alot of people. And yes searched the archived topics and refered to the helms manual........
<This is in a 99 Civic SI>
I got the 3 bolts removed. I got the vaccum on the intake plugged up, and removed the vacuum hoses, and i have the electrical connector off. But Help me!
The cable that goes through the firewall, the actuator cable.......
It connects to the top of the gas pedal. BUT, i can't get the f*##$ing thing off! It's a metal-cable that looks bolted on with a microscopic screw, how do you take this thing off??? Thanks guys, i'm just not having fun with it.
Old Nov 28, 2002 | 12:35 PM
STEALTHMODECOUPE's Avatar
Default Re: Cruise Control Removal "?" (Beave0101)
bump for you..id also like to know this..o and what did you plug your vacumm line up with??
Old Nov 28, 2002 | 12:53 PM
Beave0101's Avatar
Default Re: Cruise Control Removal "?" (STEALTHMODECOUPE)
Just go to an autoparts store, and they have "Vaccum Plugs" i bought a set with like 8 different sizes, the exact size for the manifold read " 1/8 " but no actual unit of measurement.
I keep looking at the top of the pedal, i can't see how it's even possible to remove this thing people were telling me it's a switch....
Old Nov 28, 2002 | 12:56 PM
cool thanks man!..i would go look at it right now but its like 25 degrees out and my car is buried in snow
Old Nov 29, 2002 | 12:16 AM
Beave0101's Avatar
bump for me!
Old Nov 29, 2002 | 12:46 AM
EddieHatchBlack's Avatar
Aaron removing the power steering eh? Hopefully its done by Saturday for the meet. You coming? Good luck too!
Old Nov 29, 2002 | 12:54 PM
Beave0101's Avatar
Default Re: Cruise Control Removal "?" (Eddie HatchBlack)
oh i already got rid of power steering a while ago man, but all i did was ditch the belt. So now i wanna get the rest of that crap out of my engine bay. And today is cruise control. And next week, the window washer fluid. And maybe A/C........
and i can't make the saturday cruise, that's my $$$ day, both jobs......
[Modified by Beave0101, 9:54 PM 11/29/2002]
Old Nov 30, 2002 | 03:33 AM
did u ever get the cruise control out? sorry u can't come to the meet.
Old Apr 19, 2006 | 10:31 PM
longuyen88's Avatar
Default Re: Cruise Control Removal "?" (EddieHatchBlack)
bump for how to remove the cable
Old Apr 19, 2006 | 10:34 PM
Ls_V_TurboSi's Avatar
Default Re: Cruise Control Removal "?" (longuyen88)
for starters why the hell are you bringing this 4 year old post bacak and lastly its easy. Just get down there figure out which of the 2 is for the CC and disconnect it. Very straight forward
Old Apr 19, 2006 | 11:18 PM
SOHC4life 96's Avatar
Default Re: Cruise Control Removal "?" (Ls_V_TurboSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_V_TurboSi &raquo;</TD></TR><TR><TD CLASS="quote">for starters why the hell are you bringing this 4 year old post bacak and lastly its easy. Just get down there figure out which of the 2 is for the CC and disconnect it. Very straight forward</TD></TR></TABLE>
Not nearly as easy as that. You have to bend the cable in a certain direction and slide it to one side. It's hard cause you can't see it. I just bend the thing holding it in up and pulled it out. Oh and he has a very good reason to bump the thread. He wants an answer and it's 100000000000x better than making a new thread.
to longuyen88
Old Apr 20, 2006 | 08:23 AM
longuyen88's Avatar
Default Re: Cruise Control Removal "?" (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">Not nearly as easy as that. You have to bend the cable in a certain direction and slide it to one side. It's hard cause you can't see it. I just bend the thing holding it in up and pulled it out. Oh and he has a very good reason to bump the thread. He wants an answer and it's 100000000000x better than making a new thread.
to longuyen88</TD></TR></TABLE>
thanks, I'll try that to see if i can get it off, I don't want to cut the cable and regret it later on.
and for the Ls_V_TurboSi, would you rather me post a new thread asking the same question, then have people flame on me for not searching? I did search, and I bumpped for an answer.
Old Apr 20, 2006 | 09:34 AM
E46Kid's Avatar
Ive Done This and removed my CC off my 00 Si,! if you cant remove it which i did mine( its a lil wire that hangs over the pedal) try to pull it off if that doesnt work which it should, just cut it off with a pair of dikes!
mattf22b1
Aug 17, 2019 03:14 PM
cinci00si
Feb 9, 2009 06:52 AM
sd_ej1
Dec 30, 2008 09:30 AM
Devious951
Oct 20, 2008 09:11 PM
Greyout
Apr 16, 2002 10:02 PM
