removing cruise control
Re: removing cruise control
its very very easy.
First...
disconnect the connector on the cruise control.
un-bolt cruise control(should be about 3 or 4 bolts)
then the cable leading off the cruise control goes through the fire wall and connects to the top of the gas pedal.
its kind of a pain but climb up under the dash and disconnect it from the gas pedal. make sure you disconnect the right cable. not the throtle cable cuz it connects to the gas pedal as well.
good luck i hope this helps you out
First...
