A/F guage: fairly long but please read
Old Nov 28, 2002 | 11:33 AM
1 2 NV's Avatar
Default A/F guage: fairly long but please read
alright, i asked ninesecrx this question and he didnt come up with a difinitive answer. i posted in this forum because alot of serious racers browse this place. anyways, i know the A/F guages dont work too well. but if u hook them up INDEPENDENTLY of the ECU will they b more accurate??? the reason i ask is because my uncle has a stand alone system on his rock crawling jeep. when i watched his A/F guage it was rock steady (not bouncin back and forth) except when he first floors it, then it went to lean. but throughout my ride in his jeep (yes it is EFI too) it was just movin a slight amount. so back to the original question, if u hook up the A/F guage independently will it work accurately???
Old Nov 28, 2002 | 12:00 PM
Suprdave's Avatar
Default Re: A/F guage: fairly long but please read (hondaatwsu)
I would think if it was hooked up to a Wideband, it would be more effective...
Isn't the inherant problem with them the limited voltage range of the stock O2 Sensor?
Suprdave
Old Nov 28, 2002 | 04:05 PM
kb58's Avatar
Banned
No, it won't matter. What you're decribing is a different issue of how the EFI system works, and doesn't have anything to do with "sharing" the O2 signal.
Old Nov 28, 2002 | 05:48 PM
Jared's Avatar
Default Re: A/F guage: fairly long but please read (kb58)
The gauge bouncing around is a result of the way the Honda ECM operates. It switches constantly between lean and rich to determine a proper a/f ratio for cruising, idling and fuel economy. Most stanadlone systems have closed loop as an option, most don't use it. I'm assuming your uncle's Jeep doesn't since the O2 never moves from the target a/f ratio on the gauge. 0-1v O2s are inaccurate period. Most people down the Autometer gauge as being inacurrate, but they have no proof for that. The Autometer is only as inaccurate as the limited range o2 sensor that drives it. Also, a lot of users don't understand that the O2 is meant to bounce around and that is a function of the ECM as described above. Damn, theres my rant, tired of typing, sorry.
Jared
Old Nov 28, 2002 | 07:33 PM
1 2 NV's Avatar
Default Re: A/F guage: fairly long but please read (Jared)
i know the bouncin is a result of the ECU plotting different fuel ratios. my uncles jeep runs the autometer guage with a 3 wire O2 i believe. heat, signal, and ground.
Old Nov 28, 2002 | 08:59 PM
Urban Business
Guest
Posts: n/a
yep. if your running an a/f guage of an o2 and the movement is slow, usually mean the o2 sensor is on the way to the garbage can. the guage should sweep rapidly.
o2 sensors usually send a voltage ever half seccond. independent of the ecu. the ecu knows what the intervals between readings should be under certain circumstances. if these intervals to not match up for a set period of time the ecu will thwo a code. also if the o2 sensor is shot and displays a lower voltage what what the ecu expects over a period of time it will also throw a code.
i run a voltmeter up to thousanths of a volt of an independent o2 sensor. and tune off that. works great. this method has been reported as being dead on accurate with wide band o2 sensors. id still trust a wideband more tho. however nothing has detonated to date
edit: http://www.6speed.org/wideband.php link on making your own wideband o2 sensor. saves aprox 800$ no clue on how well this works tho
[Modified by TorteX, 12:02 AM 11/29/2002]
Old Nov 29, 2002 | 12:49 PM
kb58's Avatar
Banned
Default Re: A/F guage: fairly long but please read (TorteX)
The sensor is not an active component, and puts out a <U>constant</U> voltage representing the air/fuel ratio. If the supply voltage is being pulsed then yes, the output will pulse.
Old Nov 29, 2002 | 01:14 PM
Urban Business
Guest
Posts: n/a
blah lemmie rephrease turkey got to me aparently
ecu reads o2 sensor voltage every half seccond. if these readings to not match up for a set period of time, (ie ecu isnt reading voltages at certain times) the ecu will throw a code. also if the o2 sensor is shot and displays a lower voltage what what the ecu expects over a period of time it will also throw a code.
there ya go
Old Nov 29, 2002 | 01:19 PM
kb58's Avatar
Banned
BTW, thanks for the link. I love projects like this, no hard thinking involved, just put it together
Old Nov 29, 2002 | 01:25 PM
Urban Business
Guest
Posts: n/a
93itbh22hatch
11
Mar 10, 2011 10:11 AM
ModlesSI
17
Apr 5, 2005 05:56 PM
Cyphear
Oct 6, 2004 11:24 AM
VTgringo
Aug 3, 2003 07:10 PM
AG3_Teg
Jun 25, 2003 07:10 PM
