Does this 02 Simulator Actually Work?
Re: Does this 02 Simulator Actually Work? (ModlesSI)
i tried asking the same question a couple months back... and got no replies. Who makes the sim that your showing in the picture? I've seen ones by Casper and ECG... hopefully someone has input
BUMP
BUMP
id like to know too. I've got a similar one from HARDAuto, but they didnt send me directions. My lines are VDC, Sig, GND1, and GND2
Re: Does this 02 Simulator Actually Work? (baldylox)
I tried it and it didn't work. Drive the car for xx miles and the CEL came on. So I bought the ECG Sim Box. If I can recall someone posted that it only worked for GMC cars???
Re: Does this 02 Simulator Actually Work? (degooser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by degooser »</TD></TR><TR><TD CLASS="quote">what actually does an o2 simulator do??
sorry for the stupid question....</TD></TR></TABLE>
For a simulation of secondary O2 sensor. So you can run a testpipe.
I tried running an O2 sim on my Civic and it gave me nothing but troubles. I ended up just converting to OBDI, which is better anyways.
Re: Does this 02 Simulator Actually Work? (sohc_boy)
im am also curious? i have the ecg and was going to install it this weekend. damn...i thought they were fool proof?!?! whats the easiest way to convert an obd2 00 b16 to obd1 in case i decide to go that route?
Re: Does this 02 Simulator Actually Work? (2000CX)
Get an OBDI computer from an older B16 Del Sol. I believe it is a P30, and a wiring harness. Or, you could use a chipped P28.
my friend needs an o2 simulator. has anyone used one that actually works? what about the aluminum foil trick people have used?
Re: Does this 02 Simulator Actually Work? (civicdxtyper)
according to the directions provided at this site http://home.insightbb.com/~niedejb/o2.html He says to put a resistor in-line with the ground wire and a capacitor parallel to the signal and ground.
Is that right? Shouldn't the resistor go in-line with signal instead of the ground?
Modified by Stewie at 6:50 PM 4/5/2005
Re: Does this 02 Simulator Actually Work? (Stewie)
Honda ECU's dont like o2 simulators. and when i had mine it made me run lean one day and horribly rich the next day. i ripped it out. Not worth it in my opinion.
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">Honda ECU's dont like o2 simulators. and when i had mine it made me run lean one day and horribly rich the next day. i ripped it out. Not worth it in my opinion. </TD></TR></TABLE>
I don't see how that's possible because from what I understand, the secondary o2 is not used to adj. fuel curve?
Re: (Stewie)
Does it really not mess with fuel settings? because as soon as I installed a test pipe my O2 sensor was messed up and it messed with my engine I thought it was fuel but.... maybe not
JDMflavor_EJ
11-28-2007 10:44 AM
SCsol
06-18-2005 06:20 PM
