Quickie...
I just used the Wire up by the Firewall. Its a blue wire with Silver Stripe and a Plug on the end of it. It is located on the upper right hand corner by the firewall.
Good luck, I will dig up a pic if you need it
You can tap it from behind the gauge cluster too... That's what i do when I put in tachs... Personally I don't like them... The CTR cluster is good for me.. hehe... If you got the cluster pulled out anyways to tap illumination then why not just get a ground and tach signal too... This all makes sense to me unless you are putting a tach under your hood or something...
joecivic93
Jan 6, 2004 10:07 PM
civicracer1993
Sep 17, 2002 10:53 PM
xXx Justin xXx
Jun 13, 2002 07:20 PM
