subs cutting out???
Old Nov 27, 2002 | 07:47 PM
n0 iNTegRiTY's Avatar
Default subs cutting out???
ok, i was driving along today, and my subs just randomely cut out, maybe 4 or 5 minutes after i start the car. I stopped in a parking lot to look at it to see if i could figure out whats wrong. so i rearranged the wiring to make sure that was all ok, and played with the head unit to make sure all the settings were at normal. my bass settings said it was a lot lower than i usually have it. that was strange. but i turned the settings back up, and still no bump. ???. i live in michigan and its around 0- 20 degrees here right now. so im guessing it might be the cold weather. is it possible? and also, i checked the amp, and everything is hooked up fine. so im confused. hope someone can help me out. thanks in advance.
Old Nov 27, 2002 | 07:52 PM
Default Re: subs cutting out??? (RAF LTD. 2)
i also forgot to mention that the subs are fairly new, maybe 2 or 3 months, so im pretty sure they didnt die.
Old Nov 27, 2002 | 08:06 PM
Cuong-nutz's Avatar
have you checked for a loose ground, power, or remote?
[Modified by Cuong-nutz, 11:09 PM 11/27/2002]
Old Nov 27, 2002 | 08:59 PM
Default Re: subs cutting out??? (Cuong-nutz)
no, not yet, it got dark real fast so i didnt really have time to check it out after it happened, but ill take a look at it tomorrow.
Old Nov 28, 2002 | 05:33 AM
t0p_sh0tta's Avatar
the other day i had a similar problem. There was water in my fuse coming from the battery.
Old Nov 28, 2002 | 08:01 AM
hmm... my front speakers arent working now either. wtf???
Old Nov 28, 2002 | 08:33 AM
Cuong-nutz's Avatar
could you give some more detail about your stereo setup?
it would help me and others assist you.
like are you running your speakers off amps or just for the sub?
are you using your stock headunit with an inline converter.
from what it sounds like you could have some loose wire somewhere connected to your wire harness for your headunit. a wire could be grounding out.
[Modified by Cuong-nutz, 11:36 AM 11/28/2002]
Old Nov 28, 2002 | 09:21 PM
ratherbewalking's Avatar
from the sound of it, "rearanging wires" i think thats your problem, go home take about an hour zip tie some **** up and make it look professional. id say your problem is a speaker grounding out. do you have aftermarket door speakers? if you do and the wires came off the terminals and touched metal or each other thats most likely your problem.
Old Nov 30, 2002 | 07:39 PM
Default Re: subs cutting out??? (ratherbewalking)
they are aftermarket speakers, but i know its not just that my speakers are grounding out, because it is the front speakers, and subwoofers that are not working, and everything is hooked up ok still.
Old Dec 1, 2002 | 02:15 PM
RAF LTD.'s Avatar
how about blown out amp, thats possible right?
Old Dec 11, 2002 | 04:38 PM
Default Re: subs cutting out??? (RAF LTD.)
yea, the amp is blown. case closed. dammit all, time to start saving again.
Old Dec 12, 2002 | 04:25 AM
o_Rage_o's Avatar
Default Re: subs cutting out??? (swift GTi)
you might still be able to get the output channels on the amp fixed if the amp is worth it. Otherwise, you want to make sure next time your power and ground are of the proper gauge (especially your ground).
You also would want to make sure there is no way your remote wire is coming loose anywhere.
Good luck
-Rage
Old Dec 13, 2002 | 11:43 AM
RAF LTD.'s Avatar
Default Re: subs cutting out??? (o_Rage_o)
everything is hooked up right, I looked at it and checked the ground and the remote. Fuse under battery? someone at a audio store said to switch it probably. I checked for water but that was it. Know how to do?
BTW: I am not the same person
[Modified by RAF LTD., 3:44 PM 12/13/2002]
Old Dec 13, 2002 | 03:25 PM
cRoNiC dEd's Avatar
check your battery terminal, your connection may have corroded (happened to me). It looks connected, but isn't making contact. If that's not it check your ground, as everyone is recommending. Also have someone help you, watch amp's 'power' light, see if it lights up at all, mine lit up then went dim really fast. That's how I fixed my problem, also, if your front speakers are coming off the head unit, pull it out and see if your RCA jacks and wiring harness haven't come loose off the back of the head unit.
int96gsr
Audio / Security / Video
Aug 16, 2008 06:20 AM
neli_nael
26
Jun 23, 2007 04:38 PM
skrewdriver88
12
Jul 12, 2004 01:15 AM
RallyRedGT-V6
Jun 20, 2004 11:48 AM
redwinqs
Nov 4, 2002 01:13 PM
