Help please!
Old Jun 22, 2007 | 01:43 PM
neli_nael's Avatar
Default Help please!
Ok heres the deal, I've hooked up my system correctly everything powers on but the bass doesnt hit! I'm frustrated because this is the second time its happened to me. When I first hooked it up earlier today it was working fine. Maybe 20 minutes of it working then it died on me. I don't know whats wrong! I first hooked up my Power Acoustik FUBR-10 to a cheap amp and the same thing happened to me. I replaced the rca wires and the remote wire to check if it was that. That didnt help so I thought I might have blew the amp so I upgraded to the Power Acoustik LT1920/2.
The sub is mounted on a slot ported box. I have the dual voice coils on the sub bridged to 4 ohms and the LT1920 bridged also. This is the second time its happened to me and I tried getting answers on forums when it happened the first time. Hopefully this time I might get lucky.
Could my headunit be the problem, bad rca sub-outs? How do I check? I'm not an auto audio experts so please help. Thanks.
Old Jun 22, 2007 | 02:00 PM
B18C_EJ8's Avatar
Explain, in specific detail, how you wired the sub...
Old Jun 22, 2007 | 02:08 PM
neli_nael's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Explain, in specific detail, how you wired the sub...</TD></TR></TABLE>
Positive wire --&gt; fuse --&gt; cap --&gt; amp (bridged) --&gt; sub (bridged coils 4ohms)
Old Jun 22, 2007 | 02:56 PM
B18C_EJ8's Avatar
I said nothing about wanting to know how you wired the amp.
I asked how you wired the sub.
Old Jun 22, 2007 | 04:05 PM
neli_nael's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">I said nothing about wanting to know how you wired the amp.
I asked how you wired the sub. </TD></TR></TABLE>
i bridged it, - to terminal, + from same coil to the - of the other coil and + from that coil to the terminal
Old Jun 22, 2007 | 04:08 PM
neli_nael's Avatar
Default Re: (neli_nael)
option 2
ender214's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neli_nael &raquo;</TD></TR><TR><TD CLASS="quote">
i bridged it, - to terminal, + from same coil to the - of the other coil and + from that coil to the terminal</TD></TR></TABLE>
is the sub a dual 2 ohm sub or a dual 4 ohm sub?
Old Jun 22, 2007 | 04:10 PM
neli_nael's Avatar
Default Re: (ender214)
dual 2 ohm
Old Jun 22, 2007 | 04:14 PM
ender214's Avatar
have you checked for the output out of the pre amp on the head unit.
Old Jun 22, 2007 | 04:17 PM
neli_nael's Avatar
i jus double checked and no its not blown
Old Jun 22, 2007 | 04:21 PM
ender214's Avatar
Pop test the sub...Use a battery to see if it moves.
Old Jun 22, 2007 | 04:23 PM
neli_nael's Avatar
im kinda new at this so explain to me step by step how to do that
Old Jun 22, 2007 | 04:27 PM
ender214's Avatar
take a 9 volt battery( you can use your car battery but its not very safe for the sub) take your positive wire and connect it to the positive on the battery then tap the negative on the sub to the negitive on the battery.
if your sub moves its no your sub. if it doesn't then you have found your problem.
you could also a a partially bad speaker that is taking out your amps when its playing hard.
Old Jun 22, 2007 | 04:30 PM
neli_nael's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ender214 &raquo;</TD></TR><TR><TD CLASS="quote">take a 9 volt battery( you can use your car battery but its not very safe for the sub) take your positive wire and connect it to the positive on the battery then tap the negative on the sub to the negitive on the battery.
you could also a a partially bad speaker that is taking out your amps when its playing hard.</TD></TR></TABLE>
where can i find a 9 volt battery?...only battery i have is in my car...
Old Jun 22, 2007 | 04:32 PM
ender214's Avatar
you can get a nine volt at ay drug store or gas station for like 2 bucks.
Old Jun 22, 2007 | 04:34 PM
ender214's Avatar
http://www.medicbatteries.com/....aspx
Old Jun 22, 2007 | 04:37 PM
neli_nael's Avatar
ok imma go buy one and test it.
Old Jun 22, 2007 | 05:20 PM
B18C_EJ8's Avatar
where can i find a 9 volt battery?...only battery i have is in my car...</TD></TR></TABLE>
Holy Crap...
*thud*
Old Jun 22, 2007 | 05:52 PM
ender214's Avatar
Holy Crap...
*thud*</TD></TR></TABLE>
ROFL!!!!
Old Jun 22, 2007 | 06:08 PM
mnizzy's Avatar
If you have a multimeter or voltmeter check to see if your getting power back to the amp, or see if the power light (if it has one) turns on when its hooked up. Check fuses and connections
Old Jun 22, 2007 | 07:09 PM
ender214's Avatar
Default Re: (mnizzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mnizzy &raquo;</TD></TR><TR><TD CLASS="quote">If you have a multimeter or voltmeter check to see if your getting power back to the amp, or see if the power light (if it has one) turns on when its hooked up. Check fuses and connections</TD></TR></TABLE>
Did you read the first sentence? he already said that he has power at the amp.
Old Jun 22, 2007 | 08:56 PM
neli_nael's Avatar
Holy Crap...
yea i know
Old Jun 22, 2007 | 08:59 PM
neli_nael's Avatar
so i checked it and i didnt hear any noise, is it loud?
Old Jun 23, 2007 | 03:00 AM
B18C_EJ8's Avatar
If you're hooking a 9v battery up to your sub, you're damn sure gonna notice it... If the sub does nothing, then it's toast.
Old Jun 23, 2007 | 06:22 AM
ender214's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neli_nael &raquo;</TD></TR><TR><TD CLASS="quote">so i checked it and i didnt hear any noise, is it loud?</TD></TR></TABLE>
Sounds like a blown sub. If it was damaged then it prolly took out your old amp with it.
