How do I check my timing/TDC on a H22A with Clutchmaster's flywheel
Old Nov 27, 2002 | 05:36 AM
92 in the works's Avatar
Default How do I check my timing/TDC on a H22A with Clutchmaster's flywheel
I just got finished putting in a JDM h22 in my accord and so far it hasn't started. It is throwing no codes. My father seems to think my timing is messed up somehow. Right now we set the cam gears to the #1 cylinder, and checked to see if it is at TDC, also the distributor is pointing at #1 so we are all good there. Now, my Clutchmaster's 8lb flywheel also has 2 timing marks on it, but neither of them are aligned with the pointer while everything else is at TDC. So my question is what the hell is up? Am I missing a timing mark? or is there even a timing mark there for TDC, I know I didn't put it on wrong, because it only goes on one way, so could they have sent me the wrong product? The box said for 90-2000 Accord and 92-2000 prelude. Someone help me out on this.
Old Nov 27, 2002 | 06:36 AM
satan_srv's Avatar
Default Re: How do I check my timing/TDC on a H22A with Clutchmaster's flywheel (92 in the works)
If you cam gears/cams are lined up properly at TDC and your flywheel marks are not there, then you are off timing belt teeth at the crank. The crank was obviously not at TDC when you put the timing belt on.
Old Nov 27, 2002 | 07:34 AM
Mikey3000's Avatar
my CM flywheel on my h22 has one white timing mark on it.
Old Nov 27, 2002 | 08:29 AM
str8rcn's Avatar
Default Re: How do I check my timing/TDC on a H22A with Clutchmaster's flywheel (Michael Corleone)
I had the same problem with mine.We put everything at TDC and made a mark on the flywheel,this was after checking and rechecking the t belt and cam gears.After noticing we were a few teeth off we corrected it and CM timing mark was way off so that is when me and my friend,who happens to be a Certified Honda mechanic at a Honda dealership,made the new mark and everything seems to be fine now.
Old Feb 23, 2004 | 06:57 AM
H22A EG6's Avatar
Default Re: How do I check my timing/TDC on a H22A with Clutchmaster's flywheel (str8rcn)
sorry to bring this back form the dead but if you change the timing belt does i tmess with the timing?
Old Feb 23, 2004 | 07:07 AM
thehondaguru's Avatar
Default Re: How do I check my timing/TDC on a H22A with Clutchmaster's flywheel (H22A EG6)
only if when you have it off the cam gears or such move
Old Feb 23, 2004 | 07:30 AM
H22A EG6's Avatar
Default Re: How do I check my timing/TDC on a H22A with Clutchmaster's flywheel (95 lude)
hmm i am pretty sure the did not on mine thx!
Jsarv
Engine Management and Tuning
Apr 1, 2012 01:48 PM
Mikeyjarey
Aug 14, 2009 08:57 AM
anomale
Nov 30, 2008 01:34 PM
jaydemlude
Mar 9, 2005 03:46 PM
bgod
Jul 23, 2001 06:37 AM
