Rear Big Brake Kits
Old Nov 26, 2002 | 07:30 AM
h22a4turbo's Avatar
Default Rear Big Brake Kits
Who makes the rear big brake kit for 94-97's accord? I got the front from AEM but they don't make one for the rear
Old Nov 26, 2002 | 07:45 AM
SOHCArchangel's Avatar
Default Re: Rear Big Brake Kits (h22a4turbo)
70% or more of the braking is done by the front, upgrading the rear is unnecessary and a waste of money IMHO
plus if you want larger brakes up front dont waste your money on that aem cross drilled trash
upgrade to stock blanks off the wagon/v6 which use a larger caliper which is also on the itr's and instead of using the stock caliper go and buy a 4-piston wilwood or other stock replacement for the itr and a good set of pads, and boom your done
Old Nov 26, 2002 | 08:17 AM
Stew Pidasso's Avatar
Default Re: Rear Big Brake Kits (SOHCArchangel)
Whoa, take it easy on the AEM Kit. Some of us love our AEM Big Brake kits...
Old Nov 26, 2002 | 08:28 AM
carolinaACCORD's Avatar
Default Re: Rear Big Brake Kits (Stew Pidasso)
can you use wilwood 4-pistons with the aem discs? or is it still a differnet design?
[Modified by carolinaACCORD, 12:28 PM 11/26/2002]
Old Nov 26, 2002 | 08:41 AM
Default Re: Rear Big Brake Kits (carolinaACCORD)
Being that the AEM kit uses the stock calipers, I would imagine that if the kit is an OEM replacement/upgrade it would work. It may require a little fabrication.
Old Nov 26, 2002 | 08:43 AM
actually now that i think on it, they wouldnt work. thats the whole reason you have to switch over to the v6 parts.
Old Nov 26, 2002 | 10:37 AM
WhoNeedsVtec's Avatar
the best brake upgrade and cheapier then AEM big brake or whatever,
front: Brembo blanks from the v6/wagon accord, and 90-93 legend gs 2 piston calipers, cant go wrong with that
rear: brembo blanks and better pads
new brake lines all the way around
Old Nov 26, 2002 | 10:45 AM
Default Re: Rear Big Brake Kits (WhoNeedsVtec)
Don't forget some quality high temp fluid...
Old Nov 26, 2002 | 10:46 AM
sorry i figured that was a given...but i guess i should have put it in there, thanks
Old Nov 26, 2002 | 01:57 PM
You'd be surprised on how many people don't know that the fluid affects brake performance...
Old Nov 27, 2002 | 07:35 AM
h22a4turbo's Avatar
Well I have the aem big brake kit in the front with SSBC 4 pot calipers. I have cross drilled brembo rotors in the back but it just looks too puny with my 18inch rims.
Old Nov 27, 2002 | 12:54 PM
very good point. hehe peronsally when i think about brakes i think of brake fluid, you can notice a difference with just some nice pads like axis ultamites(sp) and some nice fluid...but hey i guess everyone has to learn somewhere.
Old Dec 1, 2002 | 11:57 PM
TypeSH's Avatar
those 2pistons came on 94-95 GS sedans or 93-95 Coupes (believe all coupes, but if not definately the top trim has it).
anyone know the specs on the rear 94-95 legend GS sedan or 93-95 coupes are like? I'm curious if that caliper would fit up to the accord's rear brakes... keeping the brake setups a bit more balanced than heavy 2-pot calipers up front and dinky accord rear ones.
Old Dec 2, 2002 | 03:05 AM
b18bEG's Avatar
all you willl have to do is adj. your rear drums(if you have drums) thats what i did and it makes a large difference
Preacher
Northwest (Sales)
Nov 24, 2005 12:01 PM
Preacher
Jul 18, 2005 06:44 PM
Elkins911
Jun 20, 2003 02:59 PM
TheSwift1
May 10, 2002 06:43 PM
2K_TEG
Oct 2, 2001 06:42 AM
