fuel pressure question for guys with fp gauges
Old Nov 25, 2002 | 03:56 PM
civbeater90's Avatar
Default fuel pressure question for guys with fp gauges
ok guys once you turn your key and the pump turns on,your pressure usually rises.what happens to your pressure if you dont start your car?does the pressure drop even though you have your key turned or does it stay presurized?
Old Nov 25, 2002 | 04:23 PM
b16ahybrid's Avatar
Default Re: fuel pressure question for guys with fp gauges (civbeater90)
mine drops back down to zero.I believe there is still fuel pressure there (actually i know).why it doesn't register i don't know.Because if you were to unscrew the banjo nut on your fuel filter you would get sprayed with fuel (go ahead ask how i know ).
Old Nov 25, 2002 | 04:26 PM
Default Re: fuel pressure question for guys with fp gauges (b16ahybrid)
ok thanks im just trying to elimnate the possiblity that my pump is bad.i cant get my injectors to pulse
Old Nov 25, 2002 | 04:28 PM
b16ahybrid's Avatar
np...check your wireing
Old Nov 25, 2002 | 04:50 PM
yeah i have and everything that should have continuity does etc.but my injectors dont get pulsed to ground for some reason
aemlet
Honda Civic (2001 - 2005)
Oct 14, 2013 08:12 PM
hybridpatient95
15
Feb 10, 2006 07:03 AM
monicle
Mar 29, 2004 01:37 PM
Z6REX-SI
Jan 13, 2004 11:13 AM
TRuST
Mar 12, 2002 09:44 AM
