broken bolts
I was putting my head back togther today and the cam holder bolts broke and there are peices stuck in the threads does anyone have a good way to remove the peices. any help would be great
You might be able to use a reverse drill bit to get it out. I dont know exactly which bolt you are talking about, but usually this works to get out broken bolts.
Guest
Posts: n/a
They make tools to do this. Basically you drill a small pilot hole in the bolt with a smaller bit and then put the special tool in your drill, put the drill in reverse and it'll grab the bolt and turn it out. I think they are called Easy Outs, I've used one they work.
