ground wiring in engine
Old Nov 25, 2002 | 11:16 AM
cranberynvodka's Avatar
Default ground wiring in engine
im planing on replacing all the ground wires in my engine bay but i dont know where all of them are can someone help me out?
Old Nov 25, 2002 | 11:22 AM
Stew Pidasso's Avatar
Default Re: ground wiring in engine (cranberynvodka)
Is this in a Hyundai Excel?
Old Nov 25, 2002 | 11:56 AM
Desslok's Avatar
Default Re: ground wiring in engine (Stew Pidasso)
basically just look for any wires that go from - of battery anywhere, and any other wires that just jump from body metal to another component, such as PS pump, cam cover, etc.
Old Nov 25, 2002 | 09:47 PM
iam7head's Avatar
Default Re: ground wiring in engine (sp)
you using those ground wires kit?
Old Nov 25, 2002 | 10:28 PM
2.2dc2's Avatar
Default Re: ground wiring in engine (iam7head)
i bought a set of sun automobile hyper ground systems from sema. its the top of the line copper set with gold grounds. did not install yet due to car accident, but my friend with a type r who got the same set said he felt a noticable difference. Even the Apexi guys from sema vouched and used sun automobile's products.
Old Nov 25, 2002 | 10:57 PM
JDM_CD7's Avatar
Default Re: ground wiring in engine (2.2dc2)
Do those things really work ??
Old Nov 25, 2002 | 11:00 PM
2.2dc2's Avatar
Default Re: ground wiring in engine (JDM_CB7)
from what my friend with the r said...yes it does. and if apexi was vouching for them, i would think so. i will let you guys know how it goes when i get my new car...might be in the wrong forum though me
Old Nov 26, 2002 | 05:29 AM
Desslok's Avatar
Better grounding means more power to everything electrical, this includes your ignition, coil, sensors, etc. Just by running a heavier guage ground wire to your fuel pump you can boost the pumps output ~10-15%. Give a high power stereo system a bad, or weak ground and you will quickly realize how important a good ground is.
Old Nov 26, 2002 | 05:38 AM
dennis's Avatar
Hope you guys aren't spending too much on these "kits". You're better off just doing it yourself with some high quailty wire - can't imagine you'd need anything larger than 8 gauge, buy some pretty gold ends for them and you're golden (literally).
Bigger is not always better in electicity land... And I don't see anyone boosting output of a fuel pump with a bigger ground - it's all relative. There are many factors that determine the correct wire size. Current and length are the major ones. Research Ohm's law - there are probably some good calculators on the web too.
Old Nov 26, 2002 | 10:50 AM
gringo7718's Avatar
Default Re: ground wiring in engine (dennis)
well i did just that minus the golden connectors- you wont notice anything if your grounds are already good. if your grounds are inadequate then you might notice some difference
Old Nov 26, 2002 | 10:58 AM
KGAccord's Avatar
Default Re: ground wiring in engine (gringo7718)
Placebo Effect
Old Nov 26, 2002 | 11:17 AM
2.2dc2's Avatar
Default Re: ground wiring in engine (KGAccord)
got the top of the line kit for like 90 bucks last day at sema...retails for like 150. so i didnt spend THAT much...not like arospeeds p.o.s.
oo_phuong
Mar 16, 2008 04:37 PM
hatch96y7
Aug 16, 2006 05:19 PM
Preludster
Sep 9, 2003 10:40 AM
[HrZn]4life
Feb 3, 2003 12:02 PM
