CTR Cams
Old Nov 24, 2002 | 09:23 PM
SiRex91's Avatar
Default CTR Cams
I'm thinking about putting CTR cams into my first gen B16a because I found them for $475. I'm going to keep the stock B16a rev limit for now, is it dangerous to use these cams on a stock valvetrain even if I am using the stock revlimit?
Old Nov 24, 2002 | 09:36 PM
advanracing62's Avatar
Default Re: CTR Cams (SiRex91)
not so much.... no. Everything should be OK for now. At most you'll want to upgrade to twin springs on intake and exhaust, maybe add the LCM while you're at it if you have the $$.
Old Nov 24, 2002 | 09:54 PM
Beave0101's Avatar
no problem with stock redline whatsoever. When you do go to that (8400rpm?) reldine, at least get springs. I reccomend getting the valvetrain and higher redline because these cams are very peaky, and not worth even $475 if you dont get those few hundred rpms.......
Old Nov 24, 2002 | 10:49 PM
AWD: Jeff's Avatar
Default Re: CTR Cams (Beave0101)
i got mine for 350 good price. its not dangerous if u install it. only if u raise your revlimiter then u need a valvetrain.
03EM2guy
28
Nov 16, 2011 11:13 AM
B16Civic93
Nov 29, 2004 07:50 AM
89s1
Oct 14, 2004 03:08 PM
b18c-93
Feb 25, 2002 12:12 PM
SilentFury
Feb 9, 2002 06:30 PM
