Is there any reason why you can't run a .45 bar wg spring with high boost?
Old Nov 24, 2002 | 08:46 PM
SilverLudeSi's Avatar
New User
Default Is there any reason why you can't run a .45 bar wg spring with high boost?
When using an electronic boost controller, is there any reason you couldn't run a wastgate spring with a really low pressure rating with high boost like 20 psi? Someone is saying that "it's not a good idea," but I don't see why it would matter given how a boost controller works.
Old Nov 24, 2002 | 08:48 PM
Kamin's Avatar
Default Re: Is there any reason why you can't run a .45 bar wg spring with high boost? (SilverLudeSi)
if you have a good boost controller it works fine.
Old Nov 24, 2002 | 09:05 PM
Smashback's Avatar
I've heard the same thing. It's not the right way to do it, but haven't heard why
Old Nov 24, 2002 | 09:08 PM
sutrusu's Avatar
Default Re: Is there any reason why you can't run a .45 bar wg spring with high boost? (Hatchblack)
i heard you cant boost more than twice your wastegate spring rating
Old Nov 24, 2002 | 09:10 PM
SiRkid's Avatar
Default Re: Is there any reason why you can't run a .45 bar wg spring with high boost? (sutrusu)
ive never heard that.
lets get some real answers*cough* geoff, b18b etc*cough*
Old Nov 24, 2002 | 09:12 PM
New User
Default Re: Is there any reason why you can't run a .45 bar wg spring with high boost? (SiRkid)
yeah, i wanted to get some of the experts to weigh in on this.
Old Nov 24, 2002 | 09:15 PM
GSRrR's Avatar
Maybe its not good for the boost controller to "hold" that much pressure?
I would like to know too, not that I will ever boost that much, just something to know I guess.
Old Nov 24, 2002 | 09:35 PM
accordfreak's Avatar
Default Re: Is there any reason why you can't run a .45 bar wg spring with high boost? (GSRrR)
me too. i want to know
Old Nov 24, 2002 | 09:42 PM
jinxproof99's Avatar
New User
Default Re: Is there any reason why you can't run a .45 bar wg spring with high boost? (accordfreak)
depends on the wastegate and the boost controller. with an 8 lb spring on a hks or smaller tial, and a greddy tvvc for instance, i was maxed out at around 23 lbs. it varies but its true, the smaller the spring, the less psi you max out at(Boost).
mrbsponge
May 30, 2006 06:00 AM
yusoslo
Jul 12, 2003 08:01 PM
You_Get_Vapors
May 5, 2003 01:04 AM
Screamer
Mar 29, 2003 08:00 PM
GettaluvR
Nov 2, 2002 10:38 AM
