White smoke!!!Diagnose!!
Old Nov 24, 2002 | 08:05 PM
R-1303's Avatar
Default White smoke!!!Diagnose!!
My friends GSR is pushing out white smoke from the exhaust when revving 6-8000Rpm...what could be the cause???
Mods: intank, header, cat back exhaust..
the dealership is giving him the run around saying these mods are the cause but i don't see how at all.
Old Nov 24, 2002 | 08:07 PM
Def's Avatar
Def
Default Re: White smoke!!!Diagnose!! (R-1303)
White smoke = burning coolant
Check gaskets. Check plugs to see if there is any discoloration and that might narrow it down for you. Intake manifold gasket could be leaking and is easy to check.
BlueR's Avatar
whie smoke usually means you are running too lean also...
[Modified by BlueR, 12:08 AM 11/25/2002]
Old Nov 24, 2002 | 08:09 PM
R-1303's Avatar
Default Re: White smoke!!!Diagnose!! (BlueR)
i thought this might be oil consumption problem..but i thought also about the head gasket..the heads have never been touched.
Old Nov 24, 2002 | 08:13 PM
xjohnx's Avatar
oil consumption would be blue.
most likely is the head gasket.
heads, plural, more than one? what kind of GS-R is that!?
Old Nov 24, 2002 | 08:16 PM
R-1303's Avatar
Default Re: White smoke!!!Diagnose!! (xjohnx)
sorry head..i thought it it also might be the head gasket..but will that cause an over consumption of oil?....maybe an internal problem? crack ring lands?
Old Nov 24, 2002 | 08:39 PM
R-1303's Avatar
Old Nov 24, 2002 | 08:48 PM
TypeR 599's Avatar
you dont have to make up stories about your "friend's gsr," we all know it's your car that's blowing smoke
don't turbo hondas! haha
Old Nov 24, 2002 | 08:56 PM
ITRbroham's Avatar
shit post warrior
Default Re: White smoke!!!Diagnose!! (TypeR 599)
Alex's lame attempt at trying to help
Old Nov 24, 2002 | 09:07 PM
SoCal ITR's Avatar
Default Re: White smoke!!!Diagnose!! (ITRbroham)
So true....
Old Nov 24, 2002 | 09:09 PM
TypeR 599's Avatar
i'm just showing the man the correct way to make a honda fast. haha
still jealous of the R with the shinny radiator..
Old Nov 25, 2002 | 08:18 AM
Racebrewer's Avatar
Probably a weeping head gasket if it continues to give white smoke after fully warmed up.
Was it ever overheated (bad thermostat, etc)?
John
Old Nov 25, 2002 | 04:07 PM
R-1303's Avatar
Default Re: White smoke!!!Diagnose!! (Racebrewer)
the car has never been overheated..and always warmed up properly..it only smokes around 6000-8000 Rpm..and suggestions about the cause?
Old Nov 25, 2002 | 04:08 PM
R-1303's Avatar
make up stories?!?! who asked u to post on my thread!! u non tech bastard!
civ97
Mar 31, 2009 07:56 PM
JunkyardAccord
Nov 18, 2008 10:11 AM
MYKJDM
Jun 16, 2007 08:57 AM
R-1303
Nov 26, 2002 06:38 AM
R-1303
Nov 26, 2002 01:41 AM
