engine problems
i posted b4, when i got this used car and explained wat was wrong with it....
ok, i fixed up everything i could.... and replaced many parts... but my engine still shakes and vibrates like a ****.
-i took care of the leaking oil... it was from the valve cover (replaced gasket, and sparkplug gaskets)
-i reaplced all 4 plug wires cuz one of them wasnt working..(only 3 clyinders were working)
-i got the dist. rotor replaced.
-i got new spark plugs.
-new air cleaner
-even cleaned out the TB
-used injector cleaner fluid
BUT STILL MY CAR IS A VIBRATING ****
i spent so much time, but i still cant get it to run "quietly and smooooothly"
it vibrates the most when depressing the brake pedal (coming towards a stop light)
please help !
-new air cleaner
please help !
please help !
[/QUOTE]
Cut your rotors!!!!!!!!!
please help !
[/QUOTE]
This might be a long shot but It is a possibility...You said that I spent so much time, but i still cant get it to run "quietly and smooooothly"
please help !
[/QUOTE]
By cutting your rotors I mean sometimes the rotors for your brakes get rusted and all shitted up witch makes the car feel like its viberating....If you have them cut the problem goes away
What he means by "cut" (at least I hope so) is to have the front rotors resurfaced or turned. Also I would highly recommend inspecting all motor mounts also.
Zendos
Nov 4, 2009 04:02 PM
turboteg90
10
Sep 19, 2008 01:06 PM
