installed the turbo and tons of smoke when i boost, help please
Old Nov 24, 2002 | 07:09 PM
rbf351's Avatar
Default installed the turbo and tons of smoke when i boost, help please
i haven't reved past 5.5K yet, but when i boost i have a **** load of smoke coming out of the exhaust
it's not my oil cause i just checked it and it's still right at the top and check the intake piping and it's clean
for fuel i have the intake pump, FMU and stock (00 civic si) injectors
is there anyway to fix this without going to a dyno or tuner?
Old Nov 24, 2002 | 07:11 PM
b16ahybrid's Avatar
Default Re: installed the turbo and tons of smoke when i boost, help please (rbf351)
what kind of turbo? was it a kit or did you put it together? was the turbo new?,check the oil drain make sure it's not plugged or clogged
Old Nov 24, 2002 | 07:16 PM
T-sohctec's Avatar
what color smoke?
prolly a blown seal even If it isn't in your charge pipe. I had the same problem and it was a seal(turbine side).
good luck
[Modified by T-sohctec, 4:17 AM 11/25/2002]
rbf351's Avatar
Default Re: installed the turbo and tons of smoke when i boost, help please (b16ahybrid)
it was a revhard stage 2 kit
everything was brand new
just checlked the oil line, it's perfect not kinked or anything
Old Nov 24, 2002 | 07:18 PM
rbf351's Avatar
Default Re: installed the turbo and tons of smoke when i boost, help please (T-sohctec)
honestly i can't see what color cause it was dark out
and i put my hand over the exhaust and it smeels like fuel
Old Nov 24, 2002 | 07:19 PM
b16ahybrid's Avatar
blue smoke? and has it done it since you first installed it?
Old Nov 24, 2002 | 07:20 PM
b16ahybrid's Avatar
You probably have an injector that is stuck open, pull your dipstick and smell it, see if it smells like gas if so it's your injectors
rbf351's Avatar
not blue, from what it look like it was kinda regualr exhaust smoke, give 10 times worse
and the car used to light amout of smoke
and i just installed the turbo saturday
Old Nov 24, 2002 | 07:27 PM
rbf351's Avatar
just checked and the dipstick smells like gas
Old Nov 24, 2002 | 07:34 PM
b16ahybrid's Avatar
I'm 99% sure it's your injectors, one of them probably got stuck open so thats why it's smoking like crazy.Drain your oil, change the injectors,fill your car back up with oil, and try runing it again.Thats the problem with runing high fuel pressures with a fmu, injectors don't like really high fuel pressure.This same thing happend to my friends car, his car was even blowing smoke rings it looked kind of cool but sucked, luckly i had a set of stock injectors from my engine for him.....now's a good time to upgrade your injectors
Old Nov 24, 2002 | 07:36 PM
rbf351's Avatar
the problem is i don't have any other injectors and have to drive the car to work in the morning 20 miles each way. hopefully the engine don't blow
Old Nov 24, 2002 | 07:41 PM
b16ahybrid's Avatar
i wouldn't recomend driving it like that,If at all possible borrow somebody elses car.You run the chance of destroying your engine,gas and oil don't mix well.You will have really shitty gas mileage.not to mention the extra friction caused by thinned out oil
Judge Owens
Sep 4, 2013 07:33 PM
krazyhmongboi
May 1, 2009 03:47 PM
TnC
Mar 30, 2008 01:57 PM
kasso
Sep 8, 2005 12:05 PM
fxrob
Dec 12, 2003 03:59 PM
