brake light?
Old Nov 24, 2002 | 04:53 PM
EG_Si's Avatar
Default brake light?
hi.. im posting about my mom's 98 Accord Sedan LX..
wuts happening is that the brake light on the guage cluster stays on after she starts the car for approx.. 15 minutes.. her hand brake is indeed down and she notices no braking problems.. does anyone know what may cause this?
thanks!
Old Nov 24, 2002 | 05:05 PM
briq4's Avatar
Default Re: brake light? (EG_Si)
CHeck the fluid level. Also for some reason my 93 had issues when it would get cold out, the float would somehow get stuck and the light would come on, but there was nothing wrong with the brakes. Actually tell her to start the car and you just turn the lid and see if the light goes off.
Old Nov 24, 2002 | 05:37 PM
Big Business
Guest
Posts: n/a
Default Re: brake light? (briq4)
she might have a burnt out brake light...than happens on my 95 when one goes out
Old Nov 24, 2002 | 05:41 PM
EG_Si's Avatar
Default Re: brake light? (Foomanshu)
nope.. all the light bulbs are fine.. =\
Old Nov 24, 2002 | 05:49 PM
Desslok's Avatar
Pull of the fluid cap and make sure that rubber piece is sitting right, sometimes it gets out of shape and gets in the way of the float
Old Nov 25, 2002 | 01:41 AM
EG_Si's Avatar
Default Re: brake light? (sp)
i chcekd the float and i checked the fluid..
all are okay..
ARUGH.. nething else guys?
Old Nov 25, 2002 | 03:56 AM
urbanlegend21's Avatar
New User
check your ABS fluid level
Old Nov 25, 2002 | 05:07 AM
jweller's Avatar
Default Re: brake light? (urbanlegend21)
the e-brake light on the dash is triggered by a sensor that is directly under the e-brake lever. I'm willing to bet that switch has gone bad and is sticking. pull the center console up around the e-brake, locate the switch, and give it a shot of wd-40. that should do it.
the swithc is attached to a green wire if i remember correctly.
Old Nov 25, 2002 | 05:30 PM
EG_Si's Avatar
Default Re: brake light? (jweller)
damn.. aight.. ill have to check that after finals.. thanks a lot!!
does the stickyness of teh buttom happen a lot?
Old Nov 26, 2002 | 04:52 AM
jweller's Avatar
not frequently, but if the fluid is ok I'd check that next.
Old Nov 26, 2002 | 09:39 PM
EG_Si's Avatar
will do!
are there any other possibilities?
Old Nov 26, 2002 | 09:49 PM
95sihb's Avatar
http://community.webshots.com/photo/...51906064JUHhZv
this is a pic of my stock 96 tail light. do you see the yellow-ish box i think that is a sencer for the tailights , see if your mom has this in here car and if so you may want to replace is
[Modified by 96accordex, 10:50 PM 11/26/2002]
[Modified by 96accordex, 11:01 PM 11/26/2002]
Old Nov 26, 2002 | 10:04 PM
iam7head's Avatar
Default Re: brake light? (96accordex)
My beater's taillight also cause the brake lamp warning light on.
but for me is after the one of the light blubs burn out..
any idea how to fix it?(all blubs works and replaced now.)
lampshadej1
Nov 29, 2009 07:34 PM
sirrjibbalott
Oct 23, 2006 09:25 AM
intech
Nov 17, 2005 02:44 PM
sullycrx
Nov 16, 2005 09:48 PM
Charles B.
May 10, 2002 11:43 AM
