gas problems
Old Nov 24, 2002 | 01:11 PM
EG6owner-T's Avatar
Default gas problems
i search = nothing
but i seen a thread before, its about when i refill the gas and open the cap, pressure is not as good as it use to be(2 weeks ago) when i usually open i hear a lot of pressure come out, but now nothing. is there a leak somewhere?
if somebody can help me, i would appreciated it.
thanks for your time.
Old Nov 24, 2002 | 09:25 PM
EG6owner-T's Avatar
Default Re: gas problems (EG6owner)
i seen this thread before
i know u know
Old Nov 26, 2002 | 10:44 AM
EG6owner-T's Avatar
bump
Old Nov 26, 2002 | 10:58 AM
Perfectionist's Avatar
It could be your gas cap gasket is leaking and not holding the presure.
Old Nov 26, 2002 | 11:03 AM
EG6owner-T's Avatar
Default Re: gas problems (Perfectionist)
hmm how could that be it was just a week before it started that i dont hear pressure anymore, but i will get my bro gas cap and see if thats it
thanks for the response
anybody else
Old Nov 26, 2002 | 11:43 AM
Cynical 1's Avatar
I've never had any pressure released when I've taken my gas cap off.
Maybe I have a problem too? Doubt it.
Old Nov 26, 2002 | 12:00 PM
NWAS's Avatar
I had the same porblem it was my gas cap.
Old Nov 26, 2002 | 08:01 PM
EG6owner-T's Avatar
Default Re: gas problems (jdmsicivic)
thanks a lot guys need to try it
Old Nov 26, 2002 | 11:32 PM
intezn's Avatar
does it make a difference?
Old Nov 27, 2002 | 10:55 AM
Nikolai's Avatar
Default Re: gas problems (intezn)
The gas cap is supposed to seal, so that the vehicle's evap system can trap fuel vapors to be burned by your engine. If your fuel cap has a leak, then your evap system can't pull a vacuum on the gas tank.
If it really is leaking, however, you'll get a CEL. I got a CEL for this, and Acura replaced my gas cap, free of charge. Unless you get a CEL (at least for Integra's), then your cap should be just fine.
Thanks,
Nick
Old Nov 27, 2002 | 01:59 PM
Desslok's Avatar
Default Re: gas problems (Nikolai)
Doesn't it just hiss when your tank is almost empty? Wait until your tank is nearly empty to get gas, that will fix your "problem"
fernando.
Jan 20, 2012 02:23 PM
lickety_britches
Sep 7, 2009 07:50 AM
MidwestCivic
13
Jul 17, 2007 05:31 PM
johnnycivichb
Oct 5, 2002 05:55 AM
Turbo Powa
Oct 1, 2002 09:09 PM
