12 second or Less
Old Nov 24, 2002 | 11:39 AM
Diegolude's Avatar
Default 12 second or Less
Hey all, First off Id like to introduce myself, Im Diego from Northern California, I drive a 93' Si Lude 17' Konigs Yokohamas
All Stock .
I was wondering, How much work, and especially how much cash will it take to make an All-Motor 12 second or Less Lude. Can it be done??
I have yet to see a Lude run 12 or less off Nos.
I barely got the Car about 1 month ago. I really want to make the car fly.
Or can I make my Lude Haul ***? and Approx How Much Cash ?
Turbo System???
Cam Gears??
Exhaust??
Intake??
Headers??
New Throttle Body??
UnderDrive Pulleys??
Fuel Race Ignition??
Drop H22a4??
Fuel Pump??
If all Else, Nos??
Should I settle for mustang??
[Modified by Diegolude, 8:40 PM 11/24/2002]
Old Nov 24, 2002 | 12:01 PM
Toretto's Avatar
Default Re: 12 second or Less (Diegolude)
12's all motor is hard, I would guess it would take over 15k to run 12's all motor. Its gonna be cheaper if you bo with FI, nitrous being the cheapest. It also depends on how deep into the 12's you want to be. The differance in money and work to run a 12.9 vs a 12.0 is actually quite a bit. You could probably run a 12.9 with a 100-125 shots of nitrous, assuming you have drag radials or slicks. It also depends of the driver, there has been times when people have ran a 13.4 on a 75shot and everything else stock. I am personally all about nitrous, so I will leave the boost and all motor to others who know more than I do.
Old Nov 24, 2002 | 12:05 PM
Diegolude's Avatar
Aaaw I dont want to here that...
My friend gots a 5.0 HO and I know he will smoke me.
Hrmm Mid to High 12's I will be content with thats shaving 4 secs off Stock time right??
And how can you spray while stock?
Old Nov 24, 2002 | 12:08 PM
red92s's Avatar
Turbo System???
Kinda contradicting yourself there. The fastest ALL-MOTOR 4th gen that I know of was runnning mid-low 13's before it was sold. There are turbocharged 4th gens with 500+ hp, that should do the trick. If your goal is to run fast times at the dragstrip without spending an assload, sell the Prelude.
Old Nov 24, 2002 | 12:15 PM
laughinxxx's Avatar
New User
100 shot if your motor is in good condition and you don't abuse it. The intake manifolds are a bitch to tap for direct port though.
Old Nov 24, 2002 | 12:50 PM
Diegolude's Avatar
I consider the turbo system motor,Its artificial power to the Motor, but its legal on the road, just like superchargers.
Old Nov 24, 2002 | 12:53 PM
drift's Avatar
New User
refer to an SCC article i saw a few months ago... strip the entire car to the floorpan.
fast AND free.
but seriously, to break 12's with a 3000lb car fitted with a 160hp motor is going to take a lot of cash, boost, and creativity.
Old Nov 24, 2002 | 01:09 PM
Que_Lude's Avatar
Default Re: 12 second or Less (drift)
I think ludes are on the heavy side for a 1/4 car... Best way is to go FI like the guy said a few posts ago. It would be nice if ludes were 2700lbs or so. Big $$$ to get a fast all motor import... especially if you take it into a shop to get everything done.
Old Nov 24, 2002 | 01:17 PM
BlueShadow's Avatar
I consider the turbo system motor,Its artificial power to the Motor, but its <u>legal on the road</u>, just like superchargers.
Not if you live in California, you need to look for Turbos and Supers that have a CARB E.O number for it to be "street-legal". And IIRC no company makes a CARB legal turbo kit for the 4G Lude SI.
EDIT: BTW no matter what you do it's gonna cost you a lot of money to get your SI into the 12's. Even if you swap to an H22, you'd still have to build it up and throw in the turbo or nitrous.
[Modified by BlueShadow, 2:18 PM 11/24/2002]
Old Nov 25, 2002 | 05:55 AM
rjr162's Avatar
Default Re: 12 second or Less (BlueShadow)
you don't *have* to build it up.. just don't go abusing it all the time and it will last, atleast for a long while. You can sink about $5000-$6000 doing your own labor and be into the 12's (well i guess I'd switch your engine over to a H22A then sink the money in). That's what we did and with only 1 run last year with everything complete (and not quite tweeked yet) we pulled a 12.97 with stock internals
Old Nov 25, 2002 | 06:10 AM
lildrgn2.0's Avatar
New User
Well, an 12 second full interior prelude will run you about the price of a new car, atleast 20K. Also, be prepared to buy race gas or octane boosters, cause its going to require 13:1 or greater compression.
Also, even with the H22A is going to cost a lot of money to stay NA.
rjr162:
You ran a 12.9 with stock internals NA?
please list the setup that this was accomplished with.
Stripped, with slicks, and an act of god with out cracking open the engine.
Todd needs to be the one to answer this, but he was low 13's with full interior. Would have hit 12's with slicks and some dyno time.
Bottom line is, if you want to keep your full interior, spare, stereo, ect.. and hit 12's... be prepared to do some serious work. Nitrous, Turbo, or NA, Lots of $$ will be spent.
Old Nov 25, 2002 | 07:14 AM
JG Luder's Avatar
Default Re: 12 second or Less (Lildrgn)
Full interior 12's N/A? Not in a street car.
HA.
Old Nov 25, 2002 | 07:22 AM
Mikeyslude's Avatar
FI would be the cheapest route even after building the engine
Old Nov 25, 2002 | 07:41 AM
577HondaPrelude's Avatar
Default Re: 12 second or Less (Mikeyslude)
Just go buy a v8.
Old Nov 25, 2002 | 07:50 AM
apexii's Avatar
Save yourself a fortune, settle for the mustang.
Old Nov 25, 2002 | 08:27 AM
Finest's Avatar
If you wanted to drag, then you bought the wrong car. Shoulda gotten a Domestic with a shitty suspension and throw some nitrous on it. Cuz that's all that it's good for anyways...
But if you wanted a comfortable ride, with excellent handling, and a great daily driven car...then you made the right choice.
To get 12's all motor, get a Civic Hatch, strip it to the bone around 1600lbs, drop in an H22. The basic mods I/H/E and some slicks and you might break 12's. Maybe.
*When will people learn that not all Honda's were made to drag?* *Or that the 1/4 mile is NOT THE ONLY standard to a car's performance* Double
Old Nov 25, 2002 | 08:39 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: 12 second or Less (Prelude_RCR)
only way to have a 12 sec or better N/A full interior Prelude...... Chevy 350
Old Nov 25, 2002 | 09:08 AM
rjr162's Avatar
it's a 97 base, using an f-max kit with an NX fogger for the intercooler, using unorth pullies, custom rollhard exhaust. shell1.csionline.net/~rj162/pics/billy if you want to see the turbo install, and shell1.csionline.net/~rj162/pics/billy/current to see where it currently sits (with the NX installed). Full interior too btw.. the times are with drag slicks at www.beaversprings.com (BTW&gt;&gt; look at the 100 mph club, the car is listed.. my brother's name is Billy Rossman) he's down the list at or near the 104 section i believe)
ok i checked, i was a little off:
#107 Bill Rossman 97 Prelude 2.2 107.24MPH
[Modified by rjr162, 6:10 PM 11/25/2002]
[Modified by rjr162, 6:12 PM 11/25/2002]
Old Nov 25, 2002 | 09:25 AM
lildrgn2.0's Avatar
New User
Default Re: 12 second or Less (rjr162)
Ok.. your boosting..
We were all talking about NA...
I was about to call BS if you were saying NA ran 12's on stock internals
Old Nov 25, 2002 | 10:25 AM
rjr162's Avatar
i was replying to blueshadow's post about having to build and using turbo and nitrous.. you can just use a turbo and don't spray the nitrous into the engine on stock parts
Old Nov 25, 2002 | 11:30 AM
1fast5gp's Avatar
It's possible to make a 12 second all motor lude... All you need is a **** load of money and alot of tunning.. I'd say go with drag gen 3 turbo kit with full internals and an LSD should do the tirck. and maybe even 11s with drag radials.. who knows.. but don't buy a domestic, they are unreliable POS's
Old Nov 25, 2002 | 11:33 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: 12 second or Less (1fast5gp)
all motor means N/A, that means so forced induction of anykind
Old Nov 25, 2002 | 11:35 AM
Al Bundy's Avatar
Default Re: 12 second or Less (Boosted97Lude)
Get the mustang
Old Nov 25, 2002 | 11:45 AM
1fast5gp's Avatar
No **** N/A is all motor!!! That why i said all motor is expensive and needs alot of tuning!! and I'd go with FI as in a Turbo Kit.
Old Nov 25, 2002 | 11:58 AM
Al Bundy's Avatar
If you go turbo, you need a lot more tuning than going N/A just to let you know.
