Leaking Radiator
Anyone have a problem with the drain at the bottom center of the radiator leaking? I tried tightening it half a turn but I don't want to do any more becuase I don't want the radiator to split or anything like that. I went on Majestic honda and they have a gasket listed that apparently goes inside on that drain bolt. Has anyone replaced this?
Thanks.
Thanks.
this was Honda's description "GASKET, DRAIN **** (DENSO) " I was just wondering if anyone had the same problem and if that fixed it.
So can I assume that I should get both the plug and the gasket/0-ring? They aren't expensive at all. But the leak is getting noticeable.
Thanks!
Thanks!
anyone know the torque specifications of that drain bolt at the bottom of the radiator? It's plastic and I don't want to over tighten it...
Thanks in advance.
Thanks in advance.
you can get a new drain plug w/ o-ring from any napa/autozone/whatever for about 3$, just take your old one to them, of coarse, you must refill the system..
5 Bucks from Honda, figured might as well get what's going to fit perfectly and they even asked which Radiator I had TOYO or Denso. But I just dont' want to over tighten it and make it leak again... anyone know if there is a rule of thumb?
also when I pull out the plug how fast will the coolant drain? I want to yank the old one and put the new one on before it all drains out. I don't know that I have a large enough catch pan.
