200whp out of a STOCK COMPRESSION usdm itr motor (NA)?
Old Nov 23, 2002 | 08:36 AM
Black R's Avatar
25 Year Member
Default 200whp out of a STOCK usdm itr motor (NA)?
Let's keep this to a simple debate please.
c/r = 10.6:1 stock. You can do a thinner headgasket to bump it up a little.
You can do headwork, and whatever cams, valvetrain, i/h/e ecu combo you want...
Let's see where this takes us fella's.
Old Nov 23, 2002 | 08:42 AM
RTW DC2R's Avatar
Default Re: 200whp out of a STOCK usdm itr motor (NA)? (Black R)
I hit 178whp with just Mugen USDM Header, AEM, and no p/s. Think I could have gotten 22 more horsepower with other bolt ons?
is your 'stock' motor allowed to have a stand alone ecu or fuel management as well? that would be good for a few more ponies.
Old Nov 23, 2002 | 10:44 AM
Black R's Avatar
25 Year Member
Default Re: 200whp out of a STOCK usdm itr motor (RTW DC2)
Yes - I though I listed ecu as one of the mods... dfi, hondata, power fc, motec, whatever floats your boat...
Nobody want's to play this game, eh?
Rob :190:'s Avatar
with good tuning, proper cams, and a Hytech or SMSP exhaust, i dont see any reason why this isn't possible.
Old Nov 23, 2002 | 10:56 AM
jonas's Avatar
this isn't exactly stock with the mods you are allowing. but whatever
Old Nov 23, 2002 | 11:05 AM
GokuSSJ4's Avatar
Default Re: 200whp out of a STOCK usdm itr motor (Rob :190:)
Miguel SNIINS made 205whp (an even if is a jdm spec R , just a slit higher CR )
you can almost achieve that with a thin head gasket on the CR difference between the 2 types of motors .
[Modified by Spoon1, 8:05 PM 11/23/2002]
Old Nov 23, 2002 | 11:09 AM
xjohnx's Avatar
Default Re: 200whp out of a STOCK usdm itr motor (jonas)
MPH or CPR (one of the two) got 200 WHP with Skunk2 stage ones, he had different pistons though, running 11.3:1. Not bad though considering how mild the cams are, he was also only tuning the cam gears, and vafc.
Old Nov 23, 2002 | 11:15 AM
MK Ultra's Avatar
Header with 2.5" collector. Your choice.
Cat. Your choice.
2.5" diameter exhaust system, free of bottlenecks. Your choice.
Adjustable cam gears. Your choice.
Upgraded clutch + lightweight flywheel (doesn't add power, but well worth it anyway). Your choice.
Hondata ECU.
Dyno tuning.
Old Nov 23, 2002 | 11:17 AM
rainmanEK's Avatar
big strong guy
Default Re: 200whp out of a STOCK usdm itr motor (xjohnx)
It was MPH, Hes a badass! Somthing like 195 with stock compression!!
Give me about a month, I should yeild same results!!
eric
Old Nov 23, 2002 | 11:21 AM
Jsracingintegra
Guest
Posts: n/a
I got over 190hp at the wheels with i/h/e and toda spec b's and ericks ecu.
Old Nov 23, 2002 | 11:29 AM
chad's Avatar
Moderator
it is very possible!!!
but you will have to have a stand alone and big cams
Old Nov 23, 2002 | 11:32 AM
mafay2's Avatar
New User
All you need is a good I/H/E combo, a set of mild cams and a very good tuner!!
Old Nov 23, 2002 | 12:00 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
I'll play this game. Guys are already hitting 190whp with SMSP header, exhaust, and intake so it would see possible with tuning and a thinner head gasket.
Old Nov 23, 2002 | 12:21 PM
P73 DA9's Avatar
New User
well my friend Jason got more than 200 whp with stock B18c5 bottom end. With an HKS heder it will be even more.
http://www.superstreetonline.com/edi...&viewtype=text
Old Nov 23, 2002 | 12:22 PM
ArmyGreenITR's Avatar
Default Re: 200whp out of a STOCK usdm itr motor (ActiveAero)
MPH hit 200whp if i rember correctly.Badass
Old Nov 23, 2002 | 12:34 PM
Turbo R's Avatar
Default Re: 200whp out of a STOCK usdm itr motor (ArmyGreen EG)
please define stock. i dont understand this thread. stock means what came on the car from the dealership. at least to me
Old Nov 23, 2002 | 12:52 PM
jonas's Avatar
Default Re: 200whp out of a STOCK usdm itr motor (NA ITR)
thats what i'm saying.
i/h/e is still considered stock to me.
but he emphasized on the STOCK part since he capitalized it on the title.. yet he wants cams and the rest of the valve train just to begin with... ok.
Old Nov 23, 2002 | 12:54 PM
Paste's Avatar
Loved
ok, look at this thread, EP made 208whp on a JDM motor, with stock cams. https://honda-tech.com/zerothread?id=150679 EDIT-"i just swapped out the the us pistons for the higher compression jdm ones" only internal mod
[Modified by paste, 2:55 PM 11/23/2002]
Old Nov 23, 2002 | 12:57 PM
Turbo R's Avatar
Default Re: 200whp out of a STOCK usdm itr motor (paste)
look at the thread your in now >>>USDM<<<
Old Nov 23, 2002 | 01:00 PM
Paste's Avatar
Loved
yeah i know, he has a USDM motor with JDM pistons
from the thread:
ok..im gonna try and remember every detail of mt engine...
jdm itr pistons
mugen headgasket
mugen outer springs( )
portflow inner springs
crower ti retainers
toda cam gears
spoon t-body
mugen oil pan
mugen cai
mugen header
spoon cat-jack
mugen twin-loop
b&m fuel riser
mugen ecu
apexi vafc
other contributing items:
vp 103
lightwieght tires and wheels (mf10's and hoosier r3s03)
lightwieght flywheel (jun)
lightwieght clutch (mugen)
lightwieght rotors (mugen)
im sure these last items can be argued over...but i believe they all helped because the engine still has to accelerate them..
oh yeah...thanks ED....
no p/s or a/c
[Modified by paste, 3:02 PM 11/23/2002]
Old Nov 23, 2002 | 01:01 PM
Paste's Avatar
Loved
For the cost of headwork, you could get 3 sets of spoon balanced pistons, i would just rather get the pistons.
Old Nov 23, 2002 | 01:11 PM
Turbo R's Avatar
key work---> STOCK. Everything you just listed wasnt stock. I dont understand. no way can you make 200whp out of a STOCK ITR.
Old Nov 23, 2002 | 01:14 PM
MackSpeed-616's Avatar
stock block, meaning no mods done to engine block. valve train is open.
any mods you can do without removing or opening the motor.
Old Nov 23, 2002 | 01:20 PM
Rob :190:'s Avatar
Default Re: 200whp out of a STOCK usdm itr motor (BustaNutt-616)
this thread is confusing me, and I'm really bright.
Turbo R's Avatar
oh ok...With my C's and valvetrain in i put 192whp with stock compression. i know that it is almost useless to use Cs with stock compression because it will lower your compression. what have the B's put down with stock compression????? anyone know?>
[Modified by NA ITR, 5:24 PM 11/23/2002]
