B16A2 Block (Installing CTR Pistons) Need Info!!
Old Nov 23, 2002 | 03:46 AM
SiSpray's Avatar
Default B16A2 Block (Installing CTR Pistons) Need Info!!
Ok, I have a B16A2. I am going to install CTR pistons. Now does any machining need to be done or do the pistons fit in with everything. Ive heard that the rods need to be machined. Please explain. Are there any differences between Type-R rods and B16 rods? Where can I purchase Type R rods?
Old Nov 23, 2002 | 09:17 AM
Jackson's Avatar
Default Re: B16A2 Block (Installing CTR Pistons) Need Info!! (SiSpray)
You need to use your b16a rods. The b16b rods are too long. Have a machine shop take about a mm off of each side of the rod and then press on the new pistons. Any competant machine shop can do it. Make sure the cylinder walls still have the cross-hatch, if not, get it re-honed.
zachattack54
Feb 25, 2008 02:03 PM
vtec69
Aug 10, 2004 08:25 AM
97CTR
Apr 2, 2004 11:27 AM
JDMlyfestyle
Mar 8, 2004 03:01 PM
