Greddy Blue Box - White Wire Connection???
Old Nov 22, 2002 | 03:13 PM
Maverick77's Avatar
Default Greddy Blue Box - White Wire Connection???
Ques. 1: It looks like you connect the Green and White wires on the Blue Box, do you?
Ques. 2: I know you connect this to the MAP Sensor, but there are 3 wires that I can connect it to: Red/Yellow, White, Green/White. Which one do i connect it to?
[Modified by Maverick77, 4:17 PM 11/22/2002]
Old Nov 22, 2002 | 04:31 PM
Maverick77's Avatar
Default Re: Greddy Blue Box - White Wire Connection??? (Maverick77)
Anyone know?
Old Nov 22, 2002 | 07:47 PM
Maverick77's Avatar
ttt
Old Nov 22, 2002 | 08:17 PM
The Mole's Avatar
what it looks like to me is you just hook it into the one wire that goes to that pin on the ecu (which is D17)....
so...cut this wire and use those conectors to connect the green wire to the side that goes directly to the ecu (D17 pin), then connect the white wire to the other half of the wire you cut, (the portion that leads out to engine harness)
im not 100% sure, but i belive im correct
Chris
Old Nov 22, 2002 | 08:29 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Greddy Blue Box - White Wire Connection??? (The Mole)
Chris
You are right. The white wire goes to the Map sensor.
Old Nov 22, 2002 | 09:21 PM
The Mole's Avatar
Default Re: Greddy Blue Box - White Wire Connection??? (Arturbo)
glad i could help
chris
boosted k20
Mar 2, 2011 03:33 AM
denshu
Lighting
Nov 8, 2007 08:02 AM
jdm420da6
Jan 2, 2005 09:06 AM
jisecup
Jul 9, 2003 02:53 PM
maxim
Jan 19, 2002 06:00 PM
