Help me trouble shoot my civic
I bought a 93 cx last night, the people i bought it from had absolutley no clue about cars mechanically wise. They told me that they just had a new head put on the car, because it was overheating, and also put in a new thermostat. The figured the head job wasnt done right and sold it to me like that. So, heres the problem. I start up the car, let it get to normal temperature, and when i give it throttle, the radiator just pumps coolant into the overflow bottle, instead of into the motor, and the hose that goes from the radiator to the motor is cold. The motor has no signs of having a bad head (no coolant in oil, no abnormal smoke, runs mint!) Is there a chance that the radiator is clogged, what do you think it is?
TIA
TIA
hmm you said the rad hose that goes to the motor is cold right?
is that the top hose?
if the top hose is still cold after the motor is at normal operating temp then i would think the thermostat isnt opening
correct me if im wrong
OK, i just tested the thermostat, in boiling water on teh stove, and it wouldnt open until the water was at rapid boil, shouldnt it open before then?
Run the car till it gets hot and check the radiator for "cold spots" areas where coolant is not getting filtered.
[Modified by Black EG, 12:07 PM 11/23/2002]
Ek9_Cuhzz
12
Nov 3, 2010 02:35 PM
cheeksnme
Dec 27, 2006 09:48 AM
DRKSol
Jun 6, 2005 04:51 AM
