HELP: Overheating problem
Old Feb 15, 2002 | 08:24 PM
echo999's Avatar
New User
Default HELP: Overheating problem
Ok, I just noticed that when my engine gets hot, the point where the
top radiator hose joins with the radiator starts leaking/boiling out.
I also notice that the coolant overflow tank hasn't moved.
I'm under the impression, that when the coolant begins to boil, it's supposed to
dump into the overflow tank.
So my prognosis is that my hose is old and needs to be replaced (and/or clamp).
Am I right?
Also, what's an acceptible temperature (maximum) for coolant?
Old Feb 15, 2002 | 08:41 PM
earl's Avatar
Default Re: HELP: Overheating problem (echo999)
Tighten clamp if possible or
replace hose, clamp and maybe thermostat to be safe. 180 degrees normal.
Careful not to over tighten and break plastic radiator
Old Feb 15, 2002 | 10:40 PM
blownsi's Avatar
New User
Default Re: HELP: Overheating problem (earl)
I had the same problem, but soon afterwards when the motor got hot i heard a popping sound and coolant began to bubble out from the headgasket and it continued to overheat. Funny thing was this was on a 9:1 CR motor with no boost. Can't figure out what went wront?
Old Feb 16, 2002 | 09:22 AM
dbman96's Avatar
New User
Replace your radiator cap! Sounds like it's not allowing pressure to vent into the expansion reservoir so it has to find another way out. You should probably replace your main hoses and clamps too, but the radiator cap is one of the most common failures in a cooling system.
Old Feb 16, 2002 | 09:43 AM
TurboInteg95's Avatar
Get a new upper hose, clamp, and radiator cap.
Old Feb 16, 2002 | 10:45 AM
echo999's Avatar
New User
Default Re: HELP: Overheating problem (TurboInteg95)
I tried 2 different ones...
The stock GSR cap, and a new Fluidyne...
Sl0wH0nda
Jun 13, 2013 10:22 AM
ahs2m2
Jul 12, 2008 08:47 AM
89sparks
May 14, 2008 07:38 AM
Tim.
17
Jan 30, 2006 09:17 PM
The-LS
Jul 14, 2004 01:16 PM
