thoughs on----------------TODA timing belt=20% stronger
so what do you all thing of it?
I saw the ad in SCC and they stated that it id 20% stronger and last loner than OEM timing belt.
-also said that it is a good investment for high reving motors.
*what are all of your thought's on this?
Have you considered the Power Enterprise belt?
https://honda-tech.com/zerothread?id=309315
https://honda-tech.com/zerothread?id=292276
https://honda-tech.com/zerothread?id=243695
https://honda-tech.com/zerothread?id=216403
https://honda-tech.com/zerothread?id=181869
https://honda-tech.com/zerothread?id=169520
https://honda-tech.com/zerothread?id=175173
[Modified by P, 11:01 AM 11/22/2002]
I would assume that the Toda belt is about the same as the PE belt. I've had my PE for 2 months now, and I really like it... You can see that it is a quality peice, and it gives me peace of mind over all. If you have the extra $$$, or even if you don't, get a stronger belt when using high lift cams.
Toda says that their belt is 200% stronger than OE.... I want that thing just because it's Toda and it looks bad ***... Check it out... http://www.todaracing.com/products/h...ming_belt.html
oem_certified_accord
Sep 28, 2007 11:37 AM
Walterronny
Apr 13, 2006 01:41 PM
Cuong-nutz
49
May 1, 2005 12:52 PM
