dyno with a bad distributor/rotor
Motor is a 96 JDM itr wit US DC header, and blitz catback.
Changed the rotor, and fucked up the distributor and got 153 whp and 98wtq.
Ima get a new distributor hopefully it should fix this POS chart.
[Modified by ej6, 11:36 PM 11/21/2002]
The torque is REALLY bad. I can see the hp going up to 160s but i dont know how im going to get a 15-20 jump in torque from a distributor.
[Modified by ej6, 12:21 AM 11/22/2002]
i think myne would come out around there too, im having troubles pinpointing my ignition problem. Vtec sounds hella loud i go hella nowhere ever since i blew a distributor fuse.
Very low tq...never seen it that low before.
arno-who is hoping ray will get this fixed, and get that puppy running the way it should
How do you know if your cap and or rotor is bad? Any tell tale signs like hesitation (or ~90ft-lbs of torque in this case
When should the cap & rotor be replaced, how many miles?
).When should the cap & rotor be replaced, how many miles?
Ick yeah...get that fixed. Rosie O'Donnell makes more power then that on her way to the buffet table.
Check your rotor, do you have a CEL?
Changed my distributor, runs better, but not great.
Slight power dip at 5200-6000rpm. Maybe vtec needs to be moved lower to 5200 rpm.
Lights are dim from idle to 4k rpm if im on the gas. After 4 they get bright but i notice the engine bogs SLIGHTLY from 4k up. Light dimming problem could have something to do with power output.
When I dynoed with a bad distributor good rotor I got 153 WHP so with the new distributor power is going to be 160s which isnt bad. The torque though....I dont see it jumping from 98 to about 118.
I might not be getting enough fuel ( stock civic fuel pump ) but im not sure about this.
Anyone got any ideas on what I should do or check next?
torreypjones
Feb 9, 2007 08:24 AM
