Real High Idle
Old Nov 21, 2002 | 11:18 AM
fe519's Avatar
Default Real High Idle
Hey everyone... something weird is happening to my car. Me and my friend sprayed a bottle of the throttle body cleaner and the usual happened... hard to start, etc. Before, the idle was fine but now, its high after I sprayed the bottle in. The idle is about 2500 and I have been driving the car for about 2 weeks now. Can someone give me some ideas of what is going on? Also, he said I can adjust the idle speed with a flat head screwdriver... but is that screw really hard to turn? Thanks for the tips.
Old Nov 21, 2002 | 11:20 AM
SOHCArchangel's Avatar
Default Re: Real High Idle (fe519)
did the throttle get stuck?
idle adjustment is at the top of the t/b use screwdriver
^_^
Old Nov 21, 2002 | 11:27 AM
Accord94DX's Avatar
Default Re: Real High Idle (SOHCArchangel)
misa, what do you do wehn the adjustment screw is so corroded yu0 cannot get a screwdriver to turn it?
is the sitmaiation wif my LX-i beater.
Old Nov 21, 2002 | 11:29 AM
Default Re: Real High Idle (Accord94DX)
ah ^_^
pb blaster? try taking an impact screwdriver to it ?
Old Nov 21, 2002 | 11:30 AM
Accord94DX's Avatar
maing, like the slot you stick the screwdriver is too shallow. It just slips off. I dunno why it is that way but it pisses me off.
it idles at 250rpm.
w00t!!
Old Nov 21, 2002 | 11:31 AM
fe519's Avatar
the throttle body isnt stuck cause I tried pushing the cable holder down and when I release it, it goes back to the same high idle. How hard should the screw be to turn to adjust the idle? Thanks
Old Nov 21, 2002 | 11:32 AM
lol, damn
well if you can find the same screw from somewhere to replace it, take the t/b off, soak it in pb blaster overnight,try again. And if that does not work out use a screw extractor, drill hole, use screw extractor....
Old Nov 21, 2002 | 11:33 AM
Accord94DX's Avatar
yarg.....ill do it at work.
Old Nov 21, 2002 | 02:13 PM
Chiovnidca's Avatar
Is yout throttle cable adjusted too tight?
Old Nov 21, 2002 | 05:58 PM
fe519's Avatar
Default Re: Real High Idle (Chiovnidca)
i tried adjusting it before but like what Accord94DX said, the slot is really shallow and i remember its pretty impossible to turn. Anyone have any ideas?
TEAM_PROGRESS
26
Dec 31, 2009 07:51 AM
Toanz
Jun 23, 2008 03:57 PM
killa_lude
Aug 16, 2003 08:33 AM
Marcos
Apr 13, 2003 05:00 PM
