Zex nitrous kit
I wanted 2 drop a zex kit on my 4th gen but i was told that i had to do work an extensive amount of work to the motor in order for the motor to withstand the shots.So i bought this damn kit a while back with the intentions of dropping it in this time of year and now i just dont want to deal with it,im just gunna do an H22 swap on my 5th gen.Since i dont have no use for it im gunna put it up for sale...im just letting ya know that if anyone wants the kit ill let it go for 400...its brand new and the box hasnteven been opened.Well just let me know if anything.Thanks
im pretty shure you'll be fine runnin the zex kit.. and if you already have the h22 or money saved for it... install the zex kit and have some happy times on the stock motor before u do the swap
Who ever told you that zex was going to hurt your car or that you had to change out anything besides your plugs was a idiot. Zex is virtually fail proof!
Paul Walker also hook me up with 26" bling..nice guy!
no..here..on h-t used kit about 320 shipped
I am looking forward for a 50 shots after my engine break in
for now i dont know a jack sh_t about N20 system..
maybe someone could enlight my dumba_s
youll be fine with a zex kit
youre safe at even a 75 shot the track.
sorry guy this might sounds silly but yeah I'm gonna say it..
I was at the coffee shop the other night and
some rice boi were taking about how much NX is better than Zex..
anyone can point out the major differeces between the two?
NX kit is better then Zex by alot. First of all Zex is dry and NX is a wet kit.
<<A n2o wet kit is when the n2o is activated and spraying the system sprays a matching amount of fuel thru the nozzle with the n2o to give a “more accurate shot”
A n2o dry kit is when the n2o is activated and spraying the system uses a vacume to adjust the fuel pressure and use the cars injectors to spray the fuel accordingly>> taken from clubsi.
Pros of Zex
- Easy to install
- Self contained
- Safe if instructions are followed
Cons of Zex
- Low HP (Zex is only rated to the flywheel)
- Electrical WOT activation
- Been known to have problems “could be due to install
Pros of NX
- More HP (NX is rated to the wheel)
- Safe
- All parts are split so supposed you have a broken solenoid, you can easily replace it with another.
Cons of NX
- More Difficult to install
i know there are some other cons but i can't think of any at the moment
Good luck
Pros of Zex
- Easy to install
- Self contained
Cons of Zex
Pros of NX
- Safe
Cons of NX
Good luck
i was thinking about putting nitrous on my 4th gen 91 accord coupe ex. I figured it'd be the easiest way to get power out of my f22a4. i don't want to spend a bunch and i want something easy to install with easy maintenance. any info would be appreciated. where do you all purchase these kits?
Jeff
Jeff
Double 06
Jun 3, 2002 08:31 PM
