5lug on 92 h/b ?
You will have to swap your whole suspension, trust me, it would be worth it.
You can install 5 lug from an ITR and retain all of your stock Civic control arms, along with the stock Civic springs/shocks.
False.
False.
Ok, didn't know that. BUT, why do something half assed? Might as well get the suspension too, right?
Then again if money is tight why do a 5 lug conversion in the first place? There are more cost effective solutions for better braking.
One thing I did leave out of my earlier post:
If I did the 5 lug conversion, I'd also make sure to change to an ITR master cylinder, brake booster and proportioning valve at the same time.
I was asking cuz I already have a Bilstein-Neuspeed coil/over race suspension on my 92 h/b that I mainly use for road racing and the gsr brkes + hawk pads are still not effective enough. I also never met anyone down here who did this conversion, so before ordering this, I wanted to make sure it fits with my coil overs !
I'm sure the problem can be alleviated without having to buy 5 lug from an ITR.
can I install 5 lug ITR brakes and spindles without having to swap my suspension ??
but fastbrakes is MUCH cheaper. plus diagnose your problem, it may be pad or fluid related.
changing EVERYTHING.
use an Si one for civics
cant use the proportioning valve from an ITR since you guys have ABS.
That's the one to use.
ITR suspension and 5lug will be much better then just going to a bigger rotor size...U get all the added benefits that come with the ITR's up graded kit
So lets say for an EK... all you need is the ITR Hub, spindle, and preferably master cylinder to convert?
ITR complete front knuckle, ITR complete rear trailing arm, ITR master cylinder, ITR brake booster, and 4040 prop valve.
[Modified by skafia, 4:24 PM 11/20/2002]
duq
Apr 11, 2005 04:54 PM
HighTachB18
19
Mar 3, 2002 01:00 AM
