allot of fluid under my car.......... right at bottom of tranny?????????
Old Nov 19, 2002 | 06:32 PM
fukaintmuven's Avatar
Default allot of fluid under my car.......... right at bottom of tranny?????????
so i check the bottom of car and theres alot of fluid under tranny.... it looks like motor oil but its not from the block.......... some retards at my job checkd it and said it was coming from the rack and pinion......... does anyonw kno or had any similar probs wit leaks......???? any info helps
Old Nov 19, 2002 | 07:33 PM
memphiss13's Avatar
Default Re: allot of fluid under my car.......... right at bottom of tranny????????? (fukaintmuven)
that leak could be one of your axle seals. if it is, its an easy fix.
Old Nov 19, 2002 | 08:03 PM
TheIntegraGuy's Avatar
Default Re: allot of fluid under my car.......... right at bottom of tranny????????? (rookie2nr)
Make sure it's from the rack and pinion. It's probably tranny oil/gear oil. If it is, just change your tranny seal..
Old Nov 19, 2002 | 08:05 PM
Default Re: allot of fluid under my car.......... right at bottom of tranny????????? (Esone3)
yo.... would tranny fluid(10-40) be the same fluid as thats in the rack and pinion....
would the axle seals lead out tranny fluid or that thick grease...
rugimpy
Sep 4, 2010 04:00 PM
jdmstyleEJ6
12
Apr 2, 2010 08:07 PM
shadohconspiracy
13
Nov 4, 2007 08:32 AM
