Chipped p75 in limp mode please help
Old Mar 10, 2026 | 10:18 PM
marleynoonan's Avatar
Default Chipped p75 in limp mode please help
I bought this chipped p75 off a buddy and it was vtec converted but there was tons of corrosion on the back so I tried cleaning it the best I could but the ecu is in limp mode and when I try to data log it says j12/j4 are still connected when they are not can anyone spot the issue or point me in the right direction
Old Mar 11, 2026 | 04:49 PM
Bruno DX's Avatar
Default Re: Chipped p75 in limp mode please help
resolder all the connections on the remap chip section
Old Mar 11, 2026 | 05:01 PM
ok I tried re heating them but the solder wouldn’t melt is that because of the corrosion?
Old Mar 11, 2026 | 08:05 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You have a TON of potential troubles there with that ECU... questionable component installation, heavy corrosion causing component damage, some original capacitors and transducers are just a few... not to mention you truly don't know what is on the chip. Oh, and the ECU is at least 30 years old. I say cut your losses and find another ECU.
Old Mar 11, 2026 | 08:08 PM
the ecu works perfectly fine without the j1 jumper plus I cleared and reprogrammed the chip
Old Mar 12, 2026 | 08:00 AM
Heysoos's Avatar
Loved
Community Favorite
That board looks very questionable to me. I’d recommend getting Tyler @ oxytuned to have a look, and refurbish it for you, if it’s not already beyond repair. Look him up on the FB..
https://www.facebook.com/share/1Gc8M6URa9/?mibextid=wwXIfr
Old Mar 12, 2026 | 08:29 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If that's true, then your calibration is corrupted or the chip is damaged.
Old Mar 13, 2026 | 06:41 PM
stas32's Avatar
i'd check be using a loupe to look at all the traces, verify continuity, and resolder anything that looks sketch. If you can't melt the connection, make sure your iron has solder, and your heat is high enough. Im not sure if these boards are build with unleaded solder, but if they are, they require higher heat. Oxidation on the pins you are trying to reflow will inhibit heat transfer, i would clean it as good as you can, make sure you use flux and clean it when you're done.
Old Mar 13, 2026 | 08:13 PM
spAdam's Avatar
Loved
Community Favorite
That chipping/conversion job is hack.
if you’re not confident in it, find an expert to decide if it’s worth saving and pay them to fix it they deem it so.
ky opinion is your buddy owes you whatever you paid him for it, double if he’s the one that hacked it up.
Old Mar 26, 2026 | 10:31 PM
Alright I got a new ecu that’s in way better condition but it’s in limp mode with solid cel but the tune is working
Jmartini832
Aug 28, 2023 08:56 PM
Tong.Y
Jun 3, 2011 05:48 AM
80 dolla crx hf
Engine Management and Tuning
Aug 15, 2009 08:51 AM
92integraVTECgsr
May 2, 2009 12:13 AM
mustang5.slow
19
Mar 16, 2007 07:48 PM
