Power Locks Not Working (Not Actuators)
Old Mar 4, 2026 | 04:52 PM
Koolstir's Avatar
Default Power Locks Not Working (Not Actuators)
Hi all
Got a 1999 EX civic with power locks. I cannot for the life of me get the locks to actuate. I think the drivers door one might be dead, but I checked both rear actuators with a 12v battery and they work fine.
My lock switch is broken, so I just used some wire to simulate pressing it. It makes the blue box in the door click but nothing happens to the actuators in the car.
Has anyone experienced something similar to this? I’m combing through threads but haven’t been able to figure this out yet
Old Mar 4, 2026 | 06:54 PM
Lerp's Avatar
5 Year Member
Default Re: Power Locks Not Working (Not Actuators)
Have you checked the FSM to go through the testing process? I would start there, pretty sure there is a section about using multi-meter to test for stuff like this.
Old Mar 4, 2026 | 07:01 PM
Koolstir's Avatar
Was looking around but couldn’t find the procedure. Are you able to link it?
Old Mar 6, 2026 | 12:02 AM
Lerp's Avatar
5 Year Member
I linked it but mods removed the post because the FSM is copyrighted material apparently...? I'm asking about this.
Anyway, look on page 23-251 and scroll down from there. Door lock actuator test is on page 23-265.
Old Mar 8, 2026 | 05:23 PM
Koolstir's Avatar
Big time appreciate that, I didn’t know what I was looking for at all.
On another note, it turns out my driver actuator does work now. So I have 0 ideas what could be wrong with it. I have a feeling it’s wiring of some sort
Old Mar 9, 2026 | 04:09 PM
NVturbo's Avatar
O.G. triple O.G.
Wires at the door jamb are messed up. Had to replaced them on my old 94 EG sedan, driver side
Old Mar 10, 2026 | 11:31 AM
Koolstir's Avatar
Yeah starting to believe it’s this. Maybe a wire is open somewhere and killing the whole thing. No voltage seems to be going to the power lock actuator at all even when the switch is pressed.
Thankfully just bought a 1999 civic si that will come a temporary donor car to test some parts to double check everything!!
Appreciate the help and will report back when i figure it out
Old Mar 17, 2026 | 09:09 AM
Koolstir's Avatar
Reporting back to confirm this was it. Had a loose black wire in the door jam.
Soldered it and all power locks work now. Thank you!!
amac1989
May 13, 2020 08:07 AM
askani
Oct 18, 2012 02:01 PM
jermo
Sep 25, 2012 09:27 PM
Raiderz8418
Nov 28, 2011 04:59 PM
TravisCadello
Apr 6, 2009 06:05 PM
