D16y8 mini me swap not reaching temp
Old Jan 21, 2026 | 06:25 PM
marleynoonan's Avatar
Default D16y8 mini me swap not reaching temp
I just did a mini me swap in my 98 ek hatch and now the car never reaches temp with the heat on and blower on. If the heaters on cold it will get close to temp but never enough to cycle the rad. When I park and let it idle it will reach temp but never while driving. I feel like I’ve tried everything replaced the thermostat, coolant temp sensor and I’ve bled the coolant countless times but there’s still air in the system. There’s no visible coolant leaks.
Old Jan 22, 2026 | 03:41 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: D16y8 mini me swap not reaching temp
bleed the coolant system CORRECTLY.
Old Jan 22, 2026 | 04:10 PM
I thought I did? What’s the correct way
Old Jan 22, 2026 | 05:57 PM
NVturbo's Avatar
O.G. triple O.G.
- crank car, keep it level as possible.
- turn on heat to MAX
- make sure you're using a thermostat that is close to stock temperature
- make sure the fan is coming on
- does the thermostat open up and cycle through the engine as well as the radiator?
- does the exhaust smell like coolant?
- What type of coolant and mixture ratio are you using??
Xxax1dGriefxX
Dec 11, 2024 12:47 PM
wesb
Feb 13, 2022 07:43 PM
PphamEK
Feb 17, 2009 09:34 AM
brucepick
Nov 22, 2008 04:02 AM
b_serious
Nov 7, 2005 11:28 PM
