2000 Honda civic ex coupe
My d16y8 blew up, got a deal on a y7 manual an was wondering what will I have to change over from old engine to make it a drop in an go situation.
Just tape off the VTEC solenoid wire and it will fit exactly where your original motor went. Use the distributor intake manifold and iacv from your y8 or you may need to run an extra wire for your idle air control valve , as the DX civic with y7 use a 3 wire iacv
OP, swap in the long block and keep everything else as is. you'll have orphaned connectors for the knock sensor, VTEC pressure switch and VTEC solenoid but everything else should be golden.
check the driver's side mount bracket at the timing belt cover. I know that's different for various D-series, but can't recall which are directly compatible. swap the Y8 on if different.
As far as all the mounts an brackets go they all bolted right up no problem, an it is currently running BUT on the Auto y8 ecu, I’m planning to get a obd2b to obd2a jumper harness to run the Y7 manual ecu i got with the swap but as of right now I have a bunch of codes mostly related to the automatic transmission since it’s now gone, the only engine related one in my ecu is for the ECT which I plan to check out today, thankfully I work at Autozone so I can get parts somewhat cheap and it’s also a second car for me
Spoiler
Coyody
Sep 22, 2022 09:23 AM
Alex McCullough
Jun 16, 2019 06:45 PM
Ej1d16y8
Aug 21, 2018 04:43 PM
