F22b2 5 speed no reverse
Old Aug 31, 2025 | 07:31 PM
treydawg36's Avatar
Default F22b2 5 speed no reverse
just wanted to see if anyone had any other ideas before i declare its in the tranny, won’t shift into reverse at all like something solids blocking it and it’s not the linkage i got up on a lift and my buddy checked while i shifted through, also when i try to go into reverse after its almost sticky until i go just through the gears.
Old Sep 2, 2025 | 05:27 AM
RC Perspective's Avatar
Default Re: F22b2 5 speed no reverse
Gotta ask, did you swing it to neutral before going to reverse? It's a safety feature.
If yes, check the shift cables for proper adjustment.
Make sure the clutch, master and slave are in good working order as well.
Aside from that, I've got nothing else. I don't believe anything other than that would cause an issue, unless it's something internal in the transmission itself.
Others, feel free to correct any of that, or add to it.
StayTunedEf
Oct 24, 2012 10:26 AM
ExCon
Aug 5, 2006 12:38 PM
jincuteguy
Jul 15, 2004 05:28 PM
DOHCarp
Jun 8, 2002 04:49 PM
