weird check engine light
All. Check engine light only after 1/2 hour high spd hwy driving.(>65). once engine turned off, Does not light up again. Any thoughts, suggestions, comments or general grumbles?
What year is it? If OBD2 then plug in a scanner and check for pending codes. If OBD1 then plug a jumper into the service connector and see if you get a code from the blinking cel.
