Car won’t move after rear main job/shows Speedo shows 5mph not moving
Old Jul 27, 2025 | 07:24 AM
that1.5hatch's Avatar
Default Car won’t move after rear main job/shows Speedo shows 5mph not moving
Hi all. Recently decided to take on a rear main job on my civic as it had took a ****. This would be my first removal and reinstall of a transmission ever so I’m still learning. After I did my rear main I torqued my bolts to 76ftlbs flywheel and 19ftlbs clutch. I get everything bolted down and I go to start my car and put it in gear but it won’t move. When I hold my clutch down my Speedo goes to 0 but in neutral not moving it goes up to 5 mph. I put it in first with the car off and it still rolls on a hill. I assume it’s my axles but like I said I’m still learning so don’t dog me too bad😂
File Type: mov
Old Jul 27, 2025 | 01:32 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Car won’t move after rear main job/shows Speedo shows 5mph not moving
Make sure you bolted the shift linkage, especially the “bitch” pin. Did you installed the throw out bearing and clutch fork correctly?
Old Jul 27, 2025 | 01:39 PM
shift linkage is bolted correctly. I can hear the tranny shifting through the gears with the car off, and yes I assume the tob and clutch fork are installed correctly as I had not removed them from my transmission during removal. Also liked to note that if I throw the car into 2nd gear while running the mph goes from 0-8 instead of the normal 5 as if I was in first or neutral with no clutch engaged. I have a non lsd b16a2 trans so I’m just stumped lol. I plan on looking at it again tomorrow just wanted to get the idea on what I’d be looking for
Old Jul 27, 2025 | 02:37 PM
Ryanthegreat1's Avatar
You don't have an axle plugged in.
Speed is from the differential turning so everything to that point is working.
Old Jul 27, 2025 | 07:03 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I agree. Make sure your axles are inserted completely into the transmission/differential.
Old Aug 1, 2025 | 09:16 PM
delsolo95's Avatar
did you install the clutch pressure plate onto the flywheel the wrong way possibly.
rogue420
14
Jul 18, 2010 05:44 PM
Jk_DC2
Feb 21, 2009 08:26 AM
ch0g0nda
Jul 28, 2008 12:04 PM
standbackimapro
Dec 25, 2006 04:26 PM
greenCRV
May 17, 2006 10:00 AM
