need help
Hello everyone. I have a first gen Crv and I just replaced the thermostat. And I was ok for a day. The temp needle rises when I am idling or at a light. But as soon as I start driving. right back down? Like I mentioned. I replaced the thermostat. Could it be the sensor or the water pump? I have a fairly new engine. 73000 miles. Thank you all for any advice. If I had the money, I would hire help. I don't
Also the Honda temp gauge is basically crap. I use the Torque app and a bluetooth adapter when I want to know the actual temperature.
The fan is good, and it was going fine. Then it started. I replaced the temp sensor. OEM. drove great for about 5 miles. When I stopped at the light. The pin was on its way up. So I am at square one. But when I drive, it goes halfway on the meter as if ok. only goes up when driving.
It drops down to normal right in the middle of where it's supposed to be
So we replaced thermostat and sensor. We were running to get air out of system with rad funnel. It did fine. Fans run and looks like thermostat is opening. But it got to a point where so much air bubble coming up and began to spill all over.
luvmihatch
Nov 27, 2010 06:15 PM
onetrueshyguy
Dec 20, 2003 10:26 PM
