steering issues
i just lowered my car on ktuned upper and lower ca’s and got skunk2 pro-s-II coilovers and i noticed that my steering is really weird.
it stays straight with the steering wheel straight, but when i go over any bump it’ll knock it loose and then i’d have to hold the steering wheel turned a little bit to the left/right to keep the car straight. sometimes if i’m going down the road, the steering will just correct itself and it’ll go straight like no problem. i’m afraid my rack and pinion (no power steering) might be slipping teeth.
if i go over smaller bumps, you would be able to hear some clunking and it doesn’t effect the steering at all.
has anyone else had this issue? it’s stressing me out and i cant keep driving it like this as i think the issue is getting worse
update: steering is worse yet again and now the wheel is crunchy whenever i turn especially at lower speeds
Ventolin
May 14, 2008 11:45 AM
