What ecu do I need??? Please help
I have a 1996 dx hatchback with a d16y7 and a s40 transmission it doesn't have vtec it was a manual swap and is currently running a automatic ecu but I want to swap it out for a manual one have done tons of research the best I can find is a 37820-p2e-l32 but I'm not sure if it's gonna be what I need thanks in advance
What market are you located in ? In the US, you would need a 37820-P2E-A00 (A01 and A02 work as well). Depending on the market, a version "32" is a 50/50 shot at being a manual ECU.
The key portion of the ECU part number that corresponds with the engine type is the middle three digits: P2E is a D16Y7 ECU... always. The P2P ECU is for the SOHC VTEC D16Y8, and the P2T ECU represents the B16A2 DOHC VTEC engine.
Since you are located in the US market, the ECU part number that you want would again be: 37820-P2E-A01 (to A03). The OE replacement ECU part number ends in 337, but this would be a difficult part to find because very few ECU's have been replaced with new or reman OE units in the wild, and this part number is now discontinued.
